Kws At The Wheels
219 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
yep what a day, worked out in the end
Full boost before was at 4250rpm, think it is the same still , don't know to busy watching
the road:)
I can get 20+psi on just a footbrake if i want, no point though, anymore than 3200rpm
and 3 psi and it digs a hole on mt drag radials
  • Replies 152
Posted Images
the road:)
Darren, How much of an exhaust and what size you running?
Daz, tell the real story. It was 471.3rwkw - that point 3 can make a big difference :rofl:
Three 450-470+rwkw runs, back-to-back and in 40+'c heat. Impressive stuff.
Edited by whatsisname
4 inch dump, 3 inch exhaust full length of the car, 1 big muffler
and a little muffler at the back, i have no intention on ever using no
exhaust and race fuel..its a street car, and a challenge.
first pull was 460, then 1 or 2 degrees of timing 471, was there a 450?
can't remember
cheers
darren
Edited by S3_Girl
hey just like to update me kw output lol
well ive had my car tuned with the powere fc logit the other night and am running 1.3 bar std turbos
starting to make boost at 1900 rpm and full boost by about 3300 rpm and comes on pretty hard for std
the power fc logit is the way to go for sure i have no knock and and pulls hard all the way to 8000
prolly around 280 to 290 + easy
see how long b4 i need new turbo's
mike
So a guy is sellin his S15 and uses my dyno chart as proof of the power...
http://forum.silviansw.com/viewtopic.php?t=26296
Damn funny read.... :):D:O
Becareful guys!! Who woulda thought this shit would happen!
:laughing-smiley-014: the dumbass [insert OWNED!! image here] :laughing-smiley-014:
If he was a little smarter he could of at least photochopped it - Hi Tech Dyno, file name, power figure etc.
Nice one Busky2k.
can't remember
cheers
darren
Darren, Troy just told me the other day you have only just changes the stock brakes to 33 ones, WOW how did it used to pull up?? Ok?? Must be alot better now with that much power and now brakes you can trust...... :D
Damn funny read.... :nyaanyaa::nyaanyaa::laugh:
damn
you should reply the thread...to protect the buyers imo
nice find tho'
your car back yet andy?
nah paul...dropping it in today, if the clutch arrives
got held at customs for 7 days now (and $500 for duty + gst)
to "protect" the local business...but the thing is, nismo clutch can only be bought oversea, not made locally :nyaanyaa:
way to make money
ok time for ppls thoughts
a mate of mine his R34 made 147RWKW @ the last dyno day and that was running stock boost
he has since got another tunner to put a boost controller on just the bleed type and a fuel cut defender and now hes making 204RWKW from a NEO ive spoken to a couple of others and i really didnt think just winding boost up to 14psi on a neo would get you over 200kw
anyone elses thoughts on these NEO engines
Its around the mark considering its running the fcd. BUT 14psi is iffy on the R34 turbo.
Generally 11psi ish makes that sort of power (maybe a touch more as the R34 turbo's ted to push 10-15rwkw more than the rb25det turbo's so 210-215rwkw) when ign and fueling is optimal (ecu).
Hey Madaz
Yeah sounds right. I'd say though between 12 and 14psi he would have about half a kw difference! So he should probably put the boost down a little before things go bang.
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
