Hi
Okay I found a translatable page, here is the link.. It seems like it is a demo run attached to Tokyo Auto Salon...
http://translate.google.com/translate?prev.../08/000058.html
So if you plan on going to the AutoSalon, you might be in luck, pack warm clothes..
More D1GP stuff here..
Check these links for the D1GP Schedules for 2007.. I just got back from USA from the Irwindale Japanese finals and the All Stars, there won't be any Japanese racing until March.. The events are certainly different to the two I attended in Japan in 2k6..
http://en.wikipedia.org/wiki/2007_D1_Grand_Prix_Season
Here you can see the D1GP SL series in Japan will kick off in Feb, *hint* look under the US schedule..
https://www.d1gp.com/index.asp?PageAction=Custom&ID=2
https://www.sau.com.au/forums/topic/149868-d1-help-me/#findComment-2793969
Get used to the D1 Coffee adverts, they flog them at all D1GP events really reallly hard.. If you Japanese is poor, you will quickly get annoyed as it is in english and it will be the only english you hear most of the day... But it is still cool to see the drivers that you ahve been following for years..
https://www.sau.com.au/forums/topic/149868-d1-help-me/#findComment-2799126
    • Yeah - My key still does the chime thing. I followed the procedure but it didn't activate on the (identical) third set of keyfob that I had. I vaguely remember the alarm saying you can only pair two keys with it. Now that I've dug it up, it appears that you very much can pair keyfobs to the alarm system. (which are the fobs I use to unlock the car). I have successfully diverted the thread and can probably not use the OEM keyfob ever again unless I use the aftermarket alarm and attempt to pair the OEM keyfob to it. Which might just work, or not :D. I definitely used the nissan method and not the aftermarket alarm method.
    • What makes it worse is that Nissan made keys in the same style, for example R34 and Stagea, but they work at different frequencies or something like that. So they look the same but the remotes are not interchangeable. I learned that from some guy selling aftermarket blank keys.
    • Does your door chime work when you have the key in the lock and open the door? I've had that disabled because it's f**king annoying and it is one thing that messes with the pairing. Because now the car doesn't detect key in ignition anymore and the slide-key-in-and-out sequence does not trigger the pairing mode anymore. The service manual has a section on the various bits involved in doing the syncing. I presume it'll be similar between Stagea and R34.
    • Agree, but meh, I think is is based more on LOLS than actually apples to apples, like, who would have thunk a turbo 4 cylinder would not beat a NA 4 cylinder  I think with just basic N/A mods, like a exhaust and tune, it would be equal to the Mini in its current form, maybe I know my current 2.5 would "chop the mini" as the midrange now has a night and day difference in power delivery compared to the tuned 2.0, by around 20kwatw and 30nm from around 2k rpm "ish"....... I'm kinda hoping that they do a N/A build, either with the MZR 2.0 or with whatever they decide to use If I recall correctly they did talk about K swapping one a while ago
    • Can't see that being a thing.
