Guest Dragon
Looking at a entry level drift car and wish to keep the Skyline tradition.
Is this worth it? $13,600 landed in Aus.
Specs:
1988 Nissan Skyline R31 GTS-X Turbo 2.4L stroked engine
5 speed
kms to be advised
Black
Testarossa 2.4L stroker kit
T04R turbo with external wastegate
Aftermarket manifold
Aftermarket exhaust
HKS airpod
Aftermarket front mount intercooler
Oil cooler
5 x aftermarket gauges
Boost controller
15" Watanabe alloys with 205 / 60 R15 tyres
Adjustable suspension
4-point roll cage
Aluminium radiator
Monster tacho and shift light
Strut tower bar
Aftermarket gearshift knob
Etc.
All power options and airconditioning
Pics:
https://www.sau.com.au/forums/topic/14987-mild-gts-x-is-this-worth-it/
Guest Dragon
Yup, came through on the list. (Must admit, some interesting 15 year cars have come through. Nice Unimog. Lol)
Anyways, I was after a cheap R32 (Since have a R34 for a daily driver) for some drift work.
R31's are not my mug of coffee, yet it is something different from the norm in the Drift scene (180's, Silvia's)
Have my eyes on a GTS-4 coupe that the dealer wants $18,000 for. A bit steep. Might be the go for a sprint/track/drift car. (After making a switch for the AWD)
If I put my hand up for this GTS-X, the first thing to go would be the monster tach, then the Pine Tree air freshener.....(Give the cup holder to R31 Skyline Chick) Close the glove box, Take the stickers off it, might not regster it so to keep the cage in it. Dunno.
Anyways, has most of the goods allready on it, and it is a Skyline!
It's cheap for the mods on it.......Just wondering how laggy the T04R is with a 2.4 stroker kit.?
for 13,500 its very good landed, alot of stockish gts-x go for around the 11,000 mark. so with the cooler 2.4stroker and turbo its worth the extra 2,500 cause its gonna cost u more than that to do those mods.
where do u get all these emails from with these cars going up for auction????
Guest Dragon
Roy, no, did not go for this one (Nice tho!)
The wife said we allready had a 'play' car (4 door R34 a play car?)
She wanted a 4x4.
So, a compromise was sought. She gets a 4x4, I get a FMIC and maybe a sports suspension setup. (If we have enough dosh left over)
Besides, new contract at work involves more time away, so, I guess less track time now! :D (She will be driving the 4x4 to work, allowing me to do some mods to the R34)
lowlux, point your browser to http://www.prestigemotorsport.com.au and click on mailing list, this is the one I am subscribed to.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
    • I was surprised to see all the quick Jack models at the same prices on there. But yeah, grabbing one at 20% off would be great.
