  • Replies 41
I could be wro... wro.. not right... But I thought the ecu backed the timing off based on the inputs from the knock sensor...
ie: over time, if it senses detonation, it will record a timing setting in the ECU and all the maps will run slightly less timing.
I don't understand how a physical knock sensor could be reset. It's like one wire isn't it??
Please explain :stupid:
https://www.sau.com.au/forums/topic/14988-slow-r33/page/3/#findComment-499021
