Hi guys,
My GTS-4's 4wd system is functioning rather erratic, sometimes it works and sometimes it does not kick in at all (eg I can stomp first and smoke the rear wheels all the way to limiter without going anywhere) and other times it works really well (eg I drove it in the rain yesterday and could flog 1st, 2nd, and 3rd with full traction and lots of pull from the front wheels).
I have bled the system, the transfer case is the goods (recently changed it) and I have no error codes...
I am pretty sure I bled the system correctly (1. disconnect air bleed connector under dash, 2. bleed nipple above diff, 3. bleed nipple on actuator, 4. reconnect air bleed connector).
Any ideas?
