When should i upgrade my fuel pump?
My mods are:
Apexi pod
CAI
FMIC
Turbo back exhaust
Boost controller set at 9psi
Power FC coming in a few weeks.
I think at the moment ill be making 165rwkw.
Will fitting lets say a walbro 255L jobbie increase the pressure to my injectors?
I have to change the voltage too dont i?
CHEERS
https://www.sau.com.au/forums/topic/149938-when-should-i-upgrade-my-fuel-pump/
mate walbro is bolt in replacement and very cheap to ad!... my fuel pump failed and cost me a motor. for the price of say 200 odd its well worth it and eventualy your gona need it. if you boost it i would ad a larger volume pump
talking from personal experience, at the same stage as u i had to change my fuel pump as it was on the brink of dying at that power level. Ive got a walbro, and it seems to be doing the job. either that or u can go for bosch 044 or 040. But defineitly if ur going to tune ur pfc soon, do the pump before this. No need for reg or injectors yet...and what ryan said :D
Edited by moonus
The walbro ones are good for 300rwkw arnt they?
See the FAQ/DIY section, there is a thread there showing you how. Up till 200rwkw I'd say with a new walbro you'd be OK without it. but after this you should think about doing the mod.
Thanks mate
Do i need to change the voltage on the pump to a higher voltage?
If your gonna upgrade then dont worry about the voltage relay. It's just a neat trick for people who cant afford to upgrade their standard pump
You should upgrade the voltage line, stock or aftermarket pump IMO.
The one problem most people have when installing a bigger pump, is it does not flow the fuel thats required/specified.
The reason being is that people use the factory wiring loom for the fuel pump, and it just doesnt let the pump see the power it needs.
For you "stockish" application... its no worry generally speaking.
However, later on down the track (6-12-18months) if you change turbo and suddenly run out of fuel... you wont remember that you didnt upgrade the volts back when you did the pump, which could turn into a pain trying to work it out :laugh:
Hence i would say just get it over and done with now and save time later... but thats just what i would do
Also that Walbro will not support 300rwkw. I would not go over 240rwkw.
I had about 250 odd and pulled the return line off to see how much was flowing back to the tank when revving hard on the dyno. The flow completely stopped!
However, later on down the track (6-12-18months) if you change turbo and suddenly run out of fuel... you wont remember that you didnt upgrade the volts back when you did the pump, which could turn into a pain trying to work it out :)
I hear what your saying........I guess I assumed that only an idiot would buy a 250KW pump for a 250KW application. Sorry for assuming
I'm letting my mechanic install my pump very soon, it's a bosch 040, do I just tell him to upgrade the voltage line also, or do i need to buy some specific wires/parts etc?
Read the FAQ, its not a case of upgrading the line [yes the mod is an upgrade, but the stock line remains the same]. What you are doing is supplying a direct voltage feed to the pump via a relay. You are using the stock wire as an on/off signal carrier.
    • I haven’t taken them out of the cases yet    inside the box is this packaging which is pretty much like a massive blister pack
    • Purchased a NC MX5 a while ago Basic suspension mods done, BC coils and Whiteline sway bars  New DBA calipers, discs and pads Added some 17 x 8 Konig Decagrams with 215/45 17 PS5's Added some typical NA bolt on's, i.e. full exhaust and intake  Added 0.5ltrs with a MZR2.5 swap, nice bump in torques  Found a detachable hard top which is locked in for a colour match with my local paint shop in Feb 25, this also includes some PDR as it has received a few love taps from parking in the local shops when in the hands of my Minister for War and Finances, me, I park nowhere near other cars and typically park on the street The little thing is awesome, I drive it everywhere, it handles like a dream whether I'm up it or just cruising  But now,  because I'm a idiot, I keep looking at turbo kits....... did I mention I'm a idiot Why is dose so appealing  All of the NA 2.5 glory, well.......until sometime in 2025 anyway....🤪
    • I would not be surprised if you are the only person on earth that has the interest/desire to do that lol.  The Haltech base map is a really good starting point, the car will fire easily and drive very well, even on mild boost levels. To me, following your advice sounds like some sort of ancient Chinese water torcher lol (this is not an insult Josh, never change <3)
    • Those car show concepts from the 2000's and 2010's like the Floria and IDx were brilliant and should've gone ahead, at least one of them. But neither Honda nor Nissan are thinking about affordable performance any more, which is truly sad.  Even if Toyota's liquid hydrogen ICE development reaches the point where it's commercially viable and the infrastructure to support it, Honda/Nissan would have to wait until Toyota allow fee access to their patents to offer it with any smaller performance models they released to take advantage of it.
    • A sporty manual RWD coupe with a IL4 Honda engine would only be a good thing I assume we won't see anything released for a few years though, unless informal talks and designs have been going on for a few years,  and due to the current, and future, emmisions and safety requirements, I assume anything "sporty" they would do would be at least some hybrid thingie And hopefully anything they are thinking of has nice lines, without lots of plastic and fake bits hanging off it like that horrendous FK8 that looked like it was designed by a 13 year old The other issue of course in the current market is cost, currently the type R is around $70k, a twin is around $50k Meh, I'm old and grumpy and would rather buy a older model car and waste my coin on that than buying anything currently available new
