The next Winton Fun Day is scheduled for Sunday January 28th 2007.
The Fun Day is a "come and try" day and is designed to allow the average motorist access to a real race track under controlled conditions.
Cost:
Is $25 per driver and $25 per passenger
Programme:
Normally be there by 8.00 for scrutineering, but this can take some time.
Drivers Briefing at around 9.00 - 9.30
Driver only on track for 30 minutes sighting laps, then
Driver with passenger for 30 minutes, then
Driver only on track for 30 minutes, then
Driver only on track for 30 minutes, and so on all day until about 4.30
Requirements:
Bring your car, an Australian Standard Approved helmet, the helmet can be either open or closed face, fire proof clothes that cover you from neck to ankle to wrist (cotton or wool clothes are good). Runners are not the preferred footwear, Blundstones boots (or similar) or any leather type shoe is preferable
Make sure your car has no oil/coolant leaks, fitted seat belts, battery is secure, wheels nuts are tights, no loose items in the car or boot.
The Car does not have to be registered, but has to road/race worthy. Tyres need to be in good nick, tread depth is not normally a problem unless wire is poking out.
There are normally no checks done of lights except for brake lights except if it is an overcast, rainy day, then there may be checks for lights as well as wipers.
Tow bar tongues and bull bars must be removed.
You do not need to have a race licence, club licence or indeed a car licence abut you must be over 16 to drive or be a passenger.
And very importantly, bring a smart, alert attitude, coz there is some very fast cars out there, whilst it is not a race meeting, some people bring race cars and we push them hard to behave appropriately around first timers.
Food and drinks are available through a canteen.
https://www.sau.com.au/forums/topic/149944-winton-fun-day-a-come-and-try-day/
I'm in Mt Beauty that weekend so I might stay on an extra night and have a go. I have a mate coming too. Can we share the driving in one car?
Russ
Yep, but you both need to pay and get a wrist band.
    • Pete knows these cars well, he does my car too, if he was concerned about the traction arm length for your use he would have said so. Do you have adjustable bushes in that arm, maybe he got enough adjustment there (or maybe the bump steer was not material for your use of the car)
    • Hmm. Yes. I should have been clearer. 1000s for Haltech, for extra headroom. 725s for Nistune. You might even be OK with 640s, but if the possible power ends up much more than 300 rwkW you will run out of headroom on the 640s. That would probably be OK and a signal to not push it to that sort of power with Nistune anyway. At that level you probably do want to be thinking about engine protection functions. Oh, and all of that presumes 98 only, not E85. Well....the 1000s would allow you to run E85 at ~300rwkW territory, again, maybe sort of running out of headroom. Hard to tell with E85 - depends on the tuner as to how rich they like to set it up.
    • Yes.  The only scenario I can imagine when the answer isn't yes, is if you drive like there is highway patrol behind you at all times.  If your car currently runs, enjoy it and keep saving. Better costs more, keep saving until you can budget the better ECU. It's worth it.  Nope. Plenty of us making >300kw on unopened motors. Mine is unopened and makes about 350kw if I turn everything up, its fine (lots of caveats here, how the car will be used/abused, how long you expect the engine to last between rebuilds, how has the engine been maintained prior to coming into your ownership, etc etc).
    • Sorry just wanting to clarify, at this power goal, which should I be going? Also, More info regarding suspension, the rear upper camber arms were used to get the camber back to i believe around -0.5 ~ -1 degree (@ Road and Race in Rydalmere), I forgot the exact figure, but ALOT less camber than what it came originally which was like -2.5degrees. Are the traction arms still recommended? The bilsteins from SydneyKid, they've got 400lb/in fronts & 275/in in the rear, revalved to his specs. Intercooler, I'm just having a look at some on Rakuten.jp and some other japanese sites. Might get something from back there, GReddy, Blitz or HPI, all crossflow. Looking at roughly $450-$500 AUD + shipping... Theres not many choices except that chinese branded Justjap unless you go for blitz return flow. Yeah, only downside with Haltech is the price ahhaha, so expensive, and with all the sensors if I go that route... $$$$$ yeesh. Are headstuds/gaskets needed for <300akw?
