Yes I had the balls to bring this thing into the country, fitted it, damn it looks so farking hot it's unbelievable but I'm having second thoughts about it now.
This is a diffuser made by Abflug in Japan. Made of fibreglass (I think), with a real carbon fibre finish (for appearance perhaps?). It sits a fair bit lower than the stock lip (about 40mm) and actually bolts up to the stock lip itself.
I've installed it but only driven it from the workshop to home. It has absolutely not a scratch on it, no blemishes, nothing. It's as good as brand new.
I've decided to go for an AP 6 pot brake kit and could do with selling this as I think it's a little too low for my liking for track work at the ride height I like my car set at (IE: I love a no finger gap between the tyre and the wheel arch).
I got it through JDMyard.com which are really good mates of mine and got it at a mates rate price of $1500 shipped to Sydney. I am willing to lose a bit of cash as I have fitted it on so I'm after $1300 FIRM.
Here are some pics of it on my car:
And here are the official Abflug pics (so you can see underneath).
And here's a pic of it on a car that is pure pr0n!
I'm in Sydney and will consider shipping (at your expense) though it's not going to be easy to ship!!! PM me or email justinATaustralianinfront.com.au
As the price says, it's firm so please do not be offended if I don't reply to low offers.
That is fckn insane, looks so goddamn tough.
Why would you get lower skirts, takes away from the angry stance.
I wish i had the money for it
GL with it, worth every penny :(
I took it off the car today at IS Motor Racing (these guys also fitted it). It's got 2 light scratches under the lip (can't be seen from the front, only seen from under the car on a hoist). So, price drop $1000.00.
Comes with full instructions, and bolts/brackets to fit.
  • 1 year later...
    • Incidentally, I also put v3 of the tune on the car and did an oil change from 5w20 to 5w40 to see how it affected oil pressure in the mid to high end. I'm still happier with the thicker oil and will stick with it, but clearly the system is happy with 55psi even if I'm not!
    • So the other thing I got sorted over the weekend was Z1 oil catch can install. https://www.z1motorsports.com/z1-products/z1-motorsports/z1-q50-q60-30t-baffled-oil-catch-can-kit-p-23546.html It was a good kit, most importantly it came with preformed silicone hoses in the right shapes rather than trying to bend/join regular straight rubber hose. It did come with crappy spring clamps not proper hose clamps so I ditched them On the down side, it is made for LHD cars and RHD cars have the main ECU harness running straight through that location, I ended up bending 2 mounting brackets so the loom is up against the brake master cylinder compartment wall to make room for it....otherwise everything fit without modification Intercoolers off on both sides, but there was enough room to get everything done without disconnecting (and therefore having to re-bleed) the coolant lines. Each is mounted with 4x 12mm headed bolts, plus in and out side hose clamps (7mm headed, nice) and 3 electrical connectors on the navigator's side which were a real pain to undo (probably for the first time in 13 years).   Also one of the mounting bolts on the driver's side was cross threaded, thanks Infiniti/Nissan workshop mechanics. On the navigator's side, the catch can plumbs into the factory hose that goes from the cam cover PCV back to the intake.  This is the 2 new hoses in place. All simples and direct fit On driver's side, there is a bracket provided that mounts to the throttle body, they even provide slightly longer bolts to allow for the bracket thickness which is nice (although, they don't have captive washers like the factory bolts of course) In that pic the main loom brackets are not in place, once I had "adjusted" them across it now sits up against the panel and just clears the OCC The remaining problem with this is emptying it; currently you have to remove the 3x m4 bolts that hold it to the bracket and both banjos to remove it (probably dropping the banjo washers at the same time) pull it apart to empty then replace. I do have some fittings coming for a remote drain from underneath that will also add a little capacity...it is very small and will need to be emptied every oil change to be sure.
    • Noise sounds to me could be either wheel bearing related (have had similar from bearings going) or that tail shaft is still loose. Or something like a heat shield touching the tail shaft.
    • You wouldn't get away with saying the opposite, if you were there.
    • Do some wool fluff testing on the vents
