Yes I had the balls to bring this thing into the country, fitted it, damn it looks so farking hot it's unbelievable but I'm having second thoughts about it now.
This is a diffuser made by Abflug in Japan. Made of fibreglass (I think), with a real carbon fibre finish (for appearance perhaps?). It sits a fair bit lower than the stock lip (about 40mm) and actually bolts up to the stock lip itself.
I've installed it but only driven it from the workshop to home. It has absolutely not a scratch on it, no blemishes, nothing. It's as good as brand new.
I've decided to go for an AP 6 pot brake kit and could do with selling this as I think it's a little too low for my liking for track work at the ride height I like my car set at (IE: I love a no finger gap between the tyre and the wheel arch).
I got it through JDMyard.com which are really good mates of mine and got it at a mates rate price of $1500 shipped to Sydney. I am willing to lose a bit of cash as I have fitted it on so I'm after $1300 FIRM.
Here are some pics of it on my car:
And here are the official Abflug pics (so you can see underneath).
And here's a pic of it on a car that is pure pr0n!
I'm in Sydney and will consider shipping (at your expense) though it's not going to be easy to ship!!! PM me or email justinATaustralianinfront.com.au
As the price says, it's firm so please do not be offended if I don't reply to low offers.
  mikka33 said:
I second that!!!
Except the skirts need to be ALOT lower for the look to flow....
But yeah definetly tough from the front!
GL!
That is fckn insane, looks so goddamn tough.
Why would you get lower skirts, takes away from the angry stance.
I wish i had the money for it
GL with it, worth every penny :(
I took it off the car today at IS Motor Racing (these guys also fitted it). It's got 2 light scratches under the lip (can't be seen from the front, only seen from under the car on a hoist). So, price drop $1000.00.
Comes with full instructions, and bolts/brackets to fit.
  • 1 year later...
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
