ahah u jus have to have a responsible right leg! lol.. but yeah i fuond that wen i was on my p plates everyone would stay away from me and keep their distance.. apart from other people who wanted to race or rev me up lol... but now on my full license its as if im driving any other car. but people still give way haha.
haha... good point...
anything can be your daily driver, but I'm after a car that behaves well as a daily driver.
It will sit in traffic like any other car if you want it to (yes, a bit noisier than a falcodore - but HEAPS better looking), i was driving mine everyday with a single plate, then got a twin plate - nothing changed, it was driven everyday :)
mines a daily driver too, only 2 things that sh!t me.
every second bogan in a vs commy (with the vx clubsport kit of course), will burn past you thinkin they're the coolest man alive.
and its a pain gettin to the stock oil filter often.
but for such a hot car, they're pretty practical.
I drive mine every day and I would rate them just the same as any V8 owner driving a HSV/FPV... they chew fuel if you drive hard, wide tyres cost $$$, loud exhausts attract attention.... you just have to not only have the money to buy it... but have the money to maintain it. Any high performance car (standard or modified) will require regular maintanace, so look for a good basis (let's face it they are old now and you'll struggle to find a perfect example), look for things before they become problems, and drive it with respect.
Easy huh!!!???
Get the GTR, its a car you wont regret owning if you follow the above!
Im also a daily driver of my 32 GTR.
If you look after her and treat her right, use quality replacement parts (instead of cheap unreliable options) when things do break then you will be ok.
Just dont cut any corners with repairs otherwise you will be back as square one quicker than you think.
I love my car. Sadly im selling it.
You get that.
Mines a daily driver. Could be better on fuel but i didn't get it thinking it was gonna be fuel economical. I've had to fix a few things like suspension bushed and my front rotors but nothing major. I also had to get a new clutch but that was only because when i got it i thought the standard clutch would handle a 7k launch easily. THEY DON'T.
Whatever you get just make sure the engine is in very good condition. I haven't touched mine (apart from removing restricter) and i've never had anything go wrong with it. Thats when it becomes a money pit. When the motor starts braking.
Another daily driver here, R33 GTR.
Fuel useage is about 12l/100km if driven lightly around town.
Dudes call out from their cars, saying how cool the car is.
Those wishing thay could have a cool car hate you
fords/commo's hate you and won't race around corners. Normally the commo's want to race you in a stright line. (laugh as the $100K commo tries to round a corner to catch up to you)
Tyres aren't as bad as I expected $200 per corner for the cheaper variety
Taking kids in the back is a pain, but possible
Driving kids to school etc they love
Wife hates the small boot space
Oldies hate being througn around, taking a corner slowly.
Been pulled over by cops 4 times in 10 years, twice in the first week of owning the car. (RBT christmass)
Oil filter is a real pain to replace, without dropping oil everywhere.
Oil is real expensive and needs changing near every 2-3 months (5000km)
only uses 98 octain fuel
Parts are a pain, but probably better than any other grey imported car
Your just want the motor to do more, $$$$$
You just have to customise it. I never felt the need with the commo.
Budget for a new clutch, whats the good of a awd if you never use it for power takes offs.
Edited by a20089
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
