Hi Fellas...
I've had a crack at the search function but it's a bit too vague I'm having trouble matching others' problem with this one.
First of all, this problem doesnt occur all the time. It seems to be pretty random.
After an aggressive shift into 2nd (and sometimes but rarely, right into 3rd as well) the entire car will shudder all the way through the gear. I'll feel it in my seat, its not a huge shudder but def. noticable. The car doesn't lose power throughout. Put it into the next gear and it goes away.
One thing of note, is I'm aware that one of my fear subframe bushes have ruptured (the Gel filled ones). I have the new part ready to go, but they are not in yet. >Could this cradle movement be a potential cause of the problem?<
Keen to hear if anyone has had a similar issue. Thanks heaps guys.
Andrew
does it feel like you have haps out of balance wheels?
mine does that. just the atessa cutting in while theres no need to. it shudders the whole car. just happens randomly when driving and go over a bump etc etc.
just lift the throttle and the torque will go back to 0
Hi Fellas...
Andrew
Check all drivetrain mounting points from the engine mounts back or clutch.
Edited by Spoolemup
no comparison to a GTR i know but my R31 started doing it when i put my rb25det in.....it turned out to be the centre bearing in the tailshaft.
food for thought.
how much did it cost for you to get this fixed?
I know completly different cars and all, but my old 83 telstar did the same thing. It got worse over time. It turned out to be the torsion springs in the clutch were shagged and the clutch needed to be replaced.
My two cents (might not help, or not be the problem. Just throwing it out there)
its definately not a traction issue? if not you need more power :P dont know if cradle movement will be the problem, but maybe its making a smaller shudder much worse... assisting the problem rather than creating it
    • Well that rules out the relocation theory, however with no load, you're still getting 1.5bar of oil pressure. Can you present that data in a scatter graph over longer period? Would really highly the anomalies. Wish Haltech could do that.
    • I also understand psi but apparently most things make more sense in kpa oil pressure being one of a few exceptions so im trying to learn ahahahah, I have no idea of the relief spring pressure tbh I thought 110 which is the absolute peak it hits was about right, I was thinking of removing the relief and making sure it is in good condition, I would just replace it but couldn't find a replacement for an n1 pump too easily but I could just be blind.
    • It certainly does make sense that there is just no oil to pick up, but I can go 3 or 4 gears of WOT and have no oil pressure issues too (I have no logs of this unfortunately) and I have a fair amount of oiling mods to try and help only thing I'm missing is a rear head drain which is potentially the most helpful.
    • speaking of the relief spring and noting this is one of those stupid times where I understand imperial (psi) but the graph is in metric (kpa), it looks like the oil pressure is a little low at full noise too, isn't the relief spring 120psi/830kpa?
    • No. All these dirty old Datsuns are shitboxes. Including the GTR.
