well when im on boost i get some blue smoke. on idle and low rev driving its fine.
oil pressure is fine too.
im not sure if its my rings or my valve stem seals.
ive completely ruled out the new turbo as ive checked the cooler pipes etc.
ill be doing a compression test tomorrow to see if its my rings (mind you ive rebuilt the motor with NEW rings).
what should i be looking out for if its my valve stem seals?
https://www.sau.com.au/forums/topic/150005-blue-smoke-out-of-exhaust/
sorry to ask this question, i am curious how you guys find out that smoke is blowing out of the exhaust while you are driving? especially on boost.
revision mirror dude.
your turbo can still be burning oil without traces in your cooler pipes...the rear seal in your turbo could be gone. say movement in your turbo shaft can be pulling forward under boost so that allows oil to slip out the seal on the exhaust side. hence only on boost. idle the motor and take the oil cap off and feel for excessive blow by.
you cant really 'check' valve stem seals. you only know it was them when you change them and the smoke stops. spent hours on a 4g63 changing the valve stem seals only to find out that it was the turbo seals.
Edited by Ryanrb25
orh ok. thanks. i am wondering how to spot the problem if i happen to encounter one.
cheers
do you have a catch can???
also is it plumbed back into the inlet and or turbo ducting?
take off your rockers and check if the breathers are clogged in the rocker cover baffles,
i had similar problem after i built my engine, new turbo everthing, was blowing shit loads of smoke(blue)
found to be cause the breathers were blocked due to old engine having so much blo by..
hope this helps
Jeremy
thanks for the replies guys.
im going to compression test it today, ill take it for a drive and see if its doing it today, its a bit on and off sometimes.
ill check my breather pipe after the drive too.
any other symptoms??? misfiring... check out your spark plugs too (stupid to say i guess coz you take em out when you comp test anyway) if theyre fouled or very clean
how long since the rebuild
After my engine was built, it was doing similar things and it came down to 2 of the rings were leaking. They said it was something to do with the type of rings that were used, they either seat properley and you never have a problem or they don't and they leak. They replaced all the rings with new ones and haven't had a problem since.....
i have heard the same thing about the valve stem seals
your having the exact same symptoms as i did,
check your breathers in the rocker covers,
take them out and soak them in kero,then let them dry then put it all back in
Edited by DVS32R
the rings i used were brand new from nissan. they were placed on the right angles too (i.e. not on the thrust side of the piston).
ah fair enough, I dun have factory ring there something else. Can't think of what there made of off the top of my head....
Yeah valve stem seals going is usually evident by what I would call back off blow by.
I'd be thinking of rear turbo seal possibly. This happened to me recently.
Are you sure it's blue and not black from running rich? (Have to ask. :dry:)
Is it definitely coming OUT of the exhaust? I mean, some oil could be dripping ONTO it from somewhere possibly, although you would probably smell it when idling.
Blue under hard acceleration sounds like rings to me, of course turbo seal will do the same thing, stemseals will smoke downhill of throtle.
Don't forget slightly worn or not bedded in rings won't always show on a compression test because the oil blocks the gap and you could have perfect comp. Actualy a slightly worn engine ( bottom end, not worn valves) could have higher comp due to the fact that you may have carbon on the top of the pistons.
Do a leakdown test , then you will know for sure if you are loosing comp.
thanks mate, ill get a leakdown test done.
is there any way to check if its the turbo?
    • I know right. It baffled me. There's no way when the engine is off, key is in ignition, (coils are dissconnected aswell), also my sound system was dissconnected (I don't run any audio capacitors), battery reads 12.2v and with the 10amp fuse blown I was measuring 24 to 30v. The reading would move a bit from 30v to 24v which was weird. I took a pic of the multi meter reading 🤣: (This is a brand new single channel digital oscilloscope that also has a multi meter mode).   Before when the fuse was blown, I had one lead on the 12v supply (green/white wires) of that brown relay and the other lead on the negative battery terminal. When I turned the key on ignition (engine off), it would read 30v. Then when I removed that relay from it's plug and tried putting ignition on again, it would read 12v, but I think it's because it can't turn on the ecu now that I removed it. I asked Chatgpt and this is what it had to say:   Not sure if those theories would be possible but, any auto sparkies here? welcome to confirm. 🤷‍♂️  No idea, but if it happens again, atleast I know what type of issue it is, unlike last few months where I didn't know what was causing all my issues and I was just taking stabs in the dark to figure out what type of problem it was. If it does happen again I'm going to investigate futher and trace back the source even more and inspect more circuits. I drove it to work this morning and the car drove and boosted fine. Yeah I was thinking the same, so I've imported my back up saved map (which is the map that I saved when it got done tuning) back onto my haltech with the base fuel pressure set to 43.5psi.
    • Yeh nice, if your in melbourne could you recommend any exhaust shops in the east that do a good job?
    • Sorry yes, this is what im after Also, that jpjdm site appears to be offline
    • @Duncan Random side note, did the cops give you the driver/owners details of the taxi and then did Shannons give you a refund of the excess once you supplied those details?
    • Yeah to be clear I'm not naive, I'm sure all insurance companies are a bunch of arseholes who pay people bonusses based on the value of genuine claims they avoid....I just don't want to go back to one that has personally f**ked me multiple times in the past
