I bought this damage car because of the Advan RG mags they looks great and design to sell all the other bit and pieces!! Cars ony done 42000km
Price:
Whole car as it is $7000
Engine with loom and ECU $2500
5-Speeds Gearbox with tail shaft, Diff and two driving shaft $1800
HKS Suspension $1050
Front Seats $350 with rear seats $450
Door trims $220
Window switch both side $175
Rear wing with boot lip $140
Both tail light $120
3 inch cat back exhaust JASMA $425
All other parts available just PM me what you after thankyou!!
Car locate in Heritage Park Brisbane
Any question call 0430 073840 any time between 10am till 3am don't call between 3.01am to 9.59am thanks a lots!!
Edited by R34 GT
  • Replies 61
Posted Images
For the second time...
What condition are the sunvisors in (eg. moisture stains) and how much?
How much for the plastic surround on steering wheel (the bit between the actual wheel and dash fascia)?
I need a S2 fuel rail if its not damaged , no injectors required . Rail to manifold bolts and spacers would be good and the injector fixing screws and turrets please .
Thanks A , in Sydney .
Edited by discopotato03
where does the moisture stains?
plastic surround on steering wheel $65
how much and condition for the gearstick boot + trim,also postage to 2081 and rear suspension
gearstick boot + trim very good condition $85 inc postage
won't sell rear suspension only selling full set
can you show me what you need do you have picture??
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
