Hi,
writing this on behalf of a mate, yesterday he had a compression test done on his series 1 RB25det and all cylinders were roughly 150 except number 2 which was 65.
Question is it cheaper to rebuild or more economical to source a 2nd hand engine.
Any reccomended places in brisbane for either the rebuild or engine swap.
cheers
https://www.sau.com.au/forums/topic/150022-low-compression/
Simply, Rebuild it dude.
Had the same problem with my rb25...what ull find is a second hand engine with a limited warranty will set you back at least 2.5k and u just dont know what your getting :S
Rebuild it with decent parts and have yourself a quality engine :)
https://www.sau.com.au/forums/topic/150022-low-compression/#findComment-2795092
You have 3 options
buy a second hand piston, and a new ring- hone the bore(probably worth putting in new big ends as well) and slap it together with new head gasket prob cost you $300(only worthwhile if you do the labour yourself).
or low km import engine cost $2000 plus couple of days work.(less work than repairing old engine)
best and most expensive option is complete rebuild with stronger internals(dont bother rebuilding standard as it costs only slightly less). cost $3000+
oh and ask why did the engine fail?? faulty injector? too much boost?
https://www.sau.com.au/forums/topic/150022-low-compression/#findComment-2795699
maybe too much bouncing off the rev limiter with a faulty injector?
Alot of people do mods without anysort of tuning afterwards and drive around thinking it will be ok...only to find out later somethings gone or going.
1000 for acl forged pistons with gudgeons/rings
300 for metal headgasket
150 for bore/hone
150 for new bearings big and small
100 deck block and head
Do it yourself labourspec...all up about 1700...there could be more things that you might do while at it....eg welsh plugs, maybe some hoses or lines that need replacing...could add up to 2k.
https://www.sau.com.au/forums/topic/150022-low-compression/#findComment-2795747
If he has low comp in one bore he doesnt have a f**ked bottom end.
Bro what you need to do is sort out what parts you want and get them yourself at the best price possible. Look up nengun.com for gaskets and what not. You will need new bearings and big ends, ACL are decent. Look for forged pistons imo, ARIAS i know of are decent again...just do your research before you take the plunge.
It took me about 3 weeks of shopping around and what not to find out wat was best and most cost effective :dry:
PM me if u wanna know anything more.
https://www.sau.com.au/forums/topic/150022-low-compression/#findComment-2796860
    • Just don't use ChatGPT or any other artificial stupidity for the equivalent of googling. Their demonstrated inability to discriminate reality from hallucination should be enough to make them totally untrusted. LLMs don't know anything and cannot think to even the smallest extent. They are just predictors of the next word, and that should never be confused with capability.
    • I think, given the usage model described in the OP, I'd never ever experience the wonders of the 400kW upgrade. What I really need is boost from 2000rpm and probably no more than 260-270rwkW. But I suspect that the highflow is not actually the turbo for that purpose, so I may in fact need to get a G25 or 30 or something right sized and very spooly. We shall see after it is tuned. I've had to back the boost and boost ramp off to stop the thing from pinging since the highflow went on, so I've been almost living the NA life for 9 months now! Injectors are recently in hand. AFM is in hand. Dyno is fixed. Just need to clear a queue of f**king Supras out of the way (and probably fit my new gearbox). So....some time this year? Lol.
    • For what I gather is a Sunday/summer car....braided is fine. You're not going to be left without a vehicle and you have plenty of time for inspection/maintenance. Oof. I wouldn't use them that way. They can probably handle the temperature** but the internal corrugations means that their flow characteristics are a bit shit. Lots of extra friction and pressure loss. Makes them flow like the next pipe size down. ** They are stainless, and the stainless can usually be at least something like 304L, which is pretty good at higher temperatures (unlike 316L, which I would use for a wrt/corrosive environment, but not a particularly hot environment). But the welding needs to be top notch. And even then, because you usually need at least one cone-seat end on them (because you can twist the hose and do up both ends at the same time unless one of them is a union) they can be prone to coming loose with heat cycles.
    • I don't have the OEM oil feed lines though and the turbo-wraparound line is torn, only has water. My plan is to get replacements for these and just connect a braided line to there. And make sure it's leak free. Hoses like these are also sometimes used to connect external wastegates, so for an EGR I think you're good using them.
    • Alright I understand. The most likely case is probably gonna be that I just keep the OEM unit in the car as long as it works.
