Ok i have a cracked windshield that needs replacing. The guy quoted me $160 for it and i was pretty cool with that, however he didn't realise i wanted a shield with the antenna on the inside of the glass (as r32's have) and said one of those will cost $600 installed. I can't really justify spending all that money for a antenna. If i just run the wires around the dash a lil will i get radio reception from the major channels or will it need to be clear of the interior a bit? I don't want an exterior one, they're fugly. Is there an interior replacement or something thats cheap and i could buy, that won't be visible?
Thx
i dont know if its the same for a 33 but looks like mine has an antenna in the rear windscreen and also has a motorised one on the rear quarter.. i know the one on the quarter panel is connected to my radio, just wondering what the other one was for?
sorry for hijacking thread
You sure thats an antenna in the rear window of your 33 - mine is a demister (heater wire)!!!
well i know its got the demister ones but there is also some that are open circuit (as in they dont connect to anything else to complete the circuit) so i assumed it was an antenna of some sort
Edited by tek_01
  • 2 months later...
Sorry to hijack the thread also, but was just trying to do a search for the answer to this question...
I have just got my r32 and there is the aerial in the windscreen. Where does the wire come out which is supposed to connect to the stereo? Cos the guy i bought it from coundn't find the wire when he wired it up, and consequently the stereo does not have radio. :rofl:
Anyone able to answer this? Any help much appreciated.
Cheers
Jeremy
The wire will be a standard (may need a new coaxial end thingo to fit coz its japanese) type you will find in most cars so just look for a big black chunky cable, it's probably just hidden up a bit behind something.
Anyways, i got a new windshield in mine, was looking for a new antennae, turns out my radio works fine without an antenna, go figure.
Alright thanks, I'll have a better look and see what i can find in behind the stereo/under the climate control etc. Should it be possible to see the wire running off the bottom of the windscreen to you know?
Oh, and good to hear that your's seens to work fine without the antenna - i wish mine did :rofl:
Jeremy
Does anyone know whether it is possible to see where the wire runs down from the windscreen, or is it only possible to find it once it comes out somewhere under/behind the climate control? :P
Jeremy
Can anyone shed any light on this question?
  • 3 months later...
im just poking around in the dark, but is there something like a reception booster you can buy at dick smith?
if there is your might be able to hide it in your dash somewhere and have you 160 windscreen
hey i'm having problems with my radio as well. Just wanted to find out if you did purchase a reception booster, and if it worked. Cheers
I had the same problem, no aerial coax visible after removing the center console.
I ended up buying a indoor aerial with booster from autobarn ($24.95).
It works OK but not as good as an external aerial, but at least I have a radio to listen to now.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
