I can sell them for $99 inc postage
Them's fighting words, I'll take a pair of 4300K kits at that price thanks!
Else I think you should pull your head in. Even I know fitting these HID kits is not legal, because of the reasons bankids has mentioned. Would it stop me if I was otherwise convinced the result would be an improvement? No, of course not. The only proviso is that oncoming drivers aren't being blinded by the mod.
That is the main thing holding me back from buying an HID kit. I'd love to see some pictures of the beam cutoff pattern on R33 S2 headlights, if anyone has some spare time.
Dosent H1, H3, H4, refer to set standards? Surely its not just descriptive of the base configuration.
For example, H4 being the Hi/Low type, shouldnt there be a set distance from the base putting it at the correct focal position? Otherwise different brands would give non-consistant beam patterns.
Jordan
sorry mate ann colour under 6500k is legal that's mean any over 6500k is illegal and warranty is in australia just send me back and I will test it then send back the replacement no need to send over due to I should have enough replacement not like others supplier they all wasting time!!
Um no, any kit without DOT37 approval is illegal.
Jordan
You are right, H1, H3 and H4 (infact all of them) are different. They should have different bulb base and also different focal points. If you have a generic focal size (generic bulb0 and just vary the bulb base, the focal point will not be the same as the halogen equivalent and will result in poor light output because the housing is designed to accept a certain focal point.
  • 4 weeks later...
Guest
