Hi
Just wondering if anyone can suggest to me what this problem is...
My fuel gauge in my R33 is spastic. If you fill the car up the gauge will read full for ages... until you have maybe 30klms left before you run out. And say you only put like $20 worth in it goes to full and does the same thing...
Somone said a fuel thing in the tank but I have no idea what the part is called etc. So any suggestions on how to fix and how much it might cost?
Francesca
https://www.sau.com.au/forums/topic/150072-fuel-gauge/
Hi
Francesca
Possible the fuel sender. I had a very similar problem with mine. Basically there is a thing that sits in ur tank that reads the fuel level, mine had become un hooked from its attachment and was giving really dud readings. If u arent too confident about opening up ur fuel tank take it to a work shop and get them to chekc it. It should only cost you labour as it just hooks back on. I did have the problem of it constantly unhooking it self under high G loads drifting. There may be a way of securing it better if ur brackets that it hooks into are a bit loose.
I bet its that.
https://www.sau.com.au/forums/topic/150072-fuel-gauge/#findComment-2795988
I bet its that.
true mine was doing the same thing under high G loads, basically if u havent got any mechanical experience u can just go to ur mechanic and ask him to check the fuel sender and its float, it may either be coming un hooked or it could be catching on somthing or seizing from old age, most fuel senders are dodge, mine works now but i still rely on my speedo to tell me when its time to fill up. look at it this way least u dont own a commodore they still cant get there fuel gauge problems worked out. should have got the japs to do it.
https://www.sau.com.au/forums/topic/150072-fuel-gauge/#findComment-2810428
yeah more than likely fuel sender
could also be the gauge though, i had a problem at one stage where my gauge was reading retardedly, would just drift up and down so i had to rely on my odo to tell me when to fill up for that week
was just something to do with wiring in the end
https://www.sau.com.au/forums/topic/150072-fuel-gauge/#findComment-2811251
Just fixed this problem myself the other day.
http://www.skylinesaustralia.com/forums/in...howtopic=150741
Heaps more on the topic too:
http://www.skylinesaustralia.com/forums/in...ite=fuel+sender
Should take about 1.5 hours if your reasonably competent.
https://www.sau.com.au/forums/topic/150072-fuel-gauge/#findComment-2812636
I have had the sender replaced in my 33 but I still find that the gauge is inaccurate and fluctuates quite a bit. With the empty light on for about 20km and freaking out about running out of fuel i discovered that I had about 15 litres left in the tank.
https://www.sau.com.au/forums/topic/150072-fuel-gauge/#findComment-2813260
    • That would be interested if it's the case as seems like it would make the job a lot messier but subaru sells OEM gaskets so seems it might of had it.
    • Fuel tank is out. Looks pretty bloody good under (ie above) the fuel tank.  Amazing how good the factory e-coat holds up in the hidden areas.  No where near as much body deadener to get rid of as the front but still not looking forward to it!  Shit of a job.  I'm thinking I might grab a needle scaler and give that a go before I attack it with the angle grinder and wire wheel which is how I did the front 2/3's of the car.  Feels good to be working on the car again but who knows how long it will last!  Hopefully I can get it further forward than where it was prior to this last block of work when I decided to go back 10 steps further down the rabbit hole from where i already was! The problem is, I'm realising how hard it will be to repair and paint the bumpers, which cannot be put back on the car, and have a good paint match. There are also areas where it would be VERY hard to hide the new paint where it transitions from old paint. Like this- There is only one way to do that perfectly and I really dont want to have to do what that means I would have to do... 🤦‍♂️
    • Pretty sure the factory assembly doesn't have any gasket at all, just RTV.
    • I will get a couple cans for sure thanks, I do have 2lt fish oil to spray around the car already.
    • Thought I’d post pics of the packages for those interested. The premium package is #16. Remote start, security with tilt sensor and remote and backup battery, auto fold mirrors and door illumination.    Can post up pics of all the factory options and images from the factory options brochure if people are interested. I have all the dealer books etc for all rv37 models.
