Hey there all GTR owners plenty of threads here in regards to the R32 GTR front brakes
fair enough a lot of "if" and "maybes"
Has anyone actually used the Unique Autosports bracket (new ally one) or similar
to use R32 GTR 4 spot calipers on 324mm vspec rotors
really need some one who has actually done a similar up grade
Thanks in advance people
SIR032
Edited by SIR032GTR
I have that UAS upgrade on my car. IMO they're ok, but;
- You have to do a lot of modification of the bracket or the hub to get the brackets to bolt on. I was a bit uncomfortable with the amount of material that had to come out. You NEED an angle grinder. John will tell you they are not a easy fit.
- You have to bend the buggery out of the copper brake line to get it back in the caliper, as the bracket moves the caliper down as well as out. I was concerned with the amount of bending required.
If i were to do another i'd try the ebay ones that just move the caliper radially out rather than out and down. My guess is that they would probably bolt straight on and not require anywhere near as much bending of the brake line.
Rgs,
Kot
That is more a function that you are going from 296mm to 324mm rotors, and you cant simply offest the holes using a simple bracket. You actually need to clock the caliper around so you have sufficient meat in the caliper.
So i dont think the ebay ones for 296 to 324mm will be any different. You may be thinking about the brackets that relocate the caliper for 280 to 324mm rotors
Its a good budget upgrade...but remember its a budget upgrade. You would get a better result using new stiffer calipers suited to the rotor size you want .... which means big coin.
Honestly, if its a street car then i would stick with std caliper and rotor size with good pads and fluid and properly serviced mastger cylinder, booster etc etc.
If you are getting fade out of a properly maintained setup with good pads i respectfully request you hand in your drivers licence. :)
It appears AP are the best bang for dollar....you never see 2nd hand APs for sale...the reason is owners take them from car to car :D
I have the new type of UAS spacer that I bought on the VIC trip to NSW for 324mm rotors on a 32gtr. I'm going to have a go at installing them this w/e for Calder in a few weeks.
I'll let you know how they go. They are really cheap for what you get. Now I'm a bit worried about how easily they'll go on as as he said they were a straight fit and they had spent a lot of time to get it right. Hope you don't have the same batch as mine.
Wicked stuff Rowdyr32 I would love to hear how you go with the new UAS bracket looks killa
let me know how you go
admit though the 343mm bracket is really well made any one know where to buy cheap 343m rotors???
Cheers Everyone some really good advice
SIR032
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
    • Yeah, the plan is to just put some black rubber vacuum line caps over them to "hide" them a bit I don't want to trim them in cause I need to put the OEM box back on at some stage
    • It's a load sense idle up valve.
