Ive heard a lot of friends talk about this place not far from Richmond that they call Magnetic Mountain where you park your car on what looks to be a downhill slope, get out of it and the car will start rolling up towards you very slowly as if its being pulled toward you by a magnet, so myself, d0p3y and DJX thought we would go their lastnight to give it a go and its one of the trippiest things we had all ever experienced,
Theirs some crazy optical illusions at work here it genuinely looks like your car is rolling up a hill towards you like its being pulled by some massive magnet. So has anyone else here ever been their and if so what did you think of it? for those wanting to know how to get their just go to this link below:
Mountain
https://www.sau.com.au/forums/topic/150085-magnetic-mountainhill-richmond/
  • Replies 84
Nah no pics or vids unfortunately it was too dark we were their at about 1am, its kind of hard to explain which part exactly it happens at but if your coming along Grose Vale Road you turn left onto Bowen Mountain Road and you will see an intersection about 50 - 100 metres up or so you go past this intersection and you will see the road start to slope downwards, go down this hill about 50m then turn around and face your car back in the direction you came from turn the car off and leave it in neutral then run back up the hill and if your in the right spot the car will slowly start to roll up the hill towards you gradually picking up more speed,
Just make sure you keep a lookout for any cars coming towards you and make sure someone stays in the car to jump on the brakes incase the car rolls off into a fence or something because your in the wrong spot.
Its about 40 - 50 mins from where I live (Mt Druitt area) It only takes you about 5 - 10 mins from Richmond or if your in Penrith you could probaly get their in about 25 minutes.
Directions
The Richmond Magnetic Hill is located on Bowen Mountain Road in the Township of Mountain Bowen, just east of Richmond. The hill is located at the Mountain Bowen Rd. and Westbury Road intersection. It only works for about 50 metres going uphill.
Directions from Sydney
From Sydney City, Take the Harbour Tunnel or Harbour Bridge, follow the Warringah Expressway straight through to Lane Cove, and follow through onto the M2 Motorway right to the end till the Blacktown Exit - Turn right onto Burns Road which follows onto Old Windsor Road, which runs into Windsor Road, turn right and it will take you right into Windsor. In Winsor make a right turn onto Winsor Richmond Road (40) and it will take you to Richmond. In Richmond 40 becomes Kurrajong Road. After crossing the Hawkesbury River in North Richmond turn left on Grove Vale Road. Then turn left on Bowen Mountain Road. The Magnetic hill is on Mountain Bowen Road as soon as you pass the intersection with Westbury Road
Whereis is your friend click here
I might go back their tonight to show my GF so if I do I will take my camera and try record it im not sure how well it will turn out though as its pitch black around their at night.
This post is uselss without Video
Well if its not good enough for you go make one yourself :(
Just yeah if anyone goes play around with it for a while to make sure your in the right spot etc coz if your on a different angle or something it can look completely different and not work so just try a few different areas first.
    • I like the idea of tagging the model, and if GTS-t/GTt or GTR, and then a what, so wiring, engine, suspension.   That way you end up with a matrix, all content R33 GTST, or you can find all content that is wiring related for example.
    • You could probably just go with the genuine Nissan pads, they are not really the expensive, I can't say how they compare to your 350GT pads but at least they will give decent performance. Shims are probably the reason for the squeal.  When I bought my Q50 which runs the same Akebono brakes, the previous owner had some weird pads fitted and it squealed and dusted like crazy, I bought genuine pads and when I put them in, I found all the shims missing.  With the factory pads, the dusting is much better, performance is fine, but it still squeals when cold.  A bit of grease on the back of the pads and mounting points gets rid of it, but it comes back after a while.  I have bought a genuine shim kit that I need to install when I get around to it, hopefully that will fix the squeal.
    • Highlight that row, and a bit of trial and error. Try reducing it by 25% and see if it starts, if not, go the other way. On the newer Kebabtechs that table is in VE which makes it so much easier to calibrate.
    • That's the one I have in my R32. There isn't a bigger battery that will fit an R32.
    • Not sure what you mean haha. That one doesn't fit mine but when I get sick of my one I'll get a standard one. I just gotta find a way to make it fit cause some shit is in the way.
