Ive heard a lot of friends talk about this place not far from Richmond that they call Magnetic Mountain where you park your car on what looks to be a downhill slope, get out of it and the car will start rolling up towards you very slowly as if its being pulled toward you by a magnet, so myself, d0p3y and DJX thought we would go their lastnight to give it a go and its one of the trippiest things we had all ever experienced,
Theirs some crazy optical illusions at work here it genuinely looks like your car is rolling up a hill towards you like its being pulled by some massive magnet. So has anyone else here ever been their and if so what did you think of it? for those wanting to know how to get their just go to this link below:
Mountain
https://www.sau.com.au/forums/topic/150085-magnetic-mountainhill-richmond/
  • Replies 84
Nah no pics or vids unfortunately it was too dark we were their at about 1am, its kind of hard to explain which part exactly it happens at but if your coming along Grose Vale Road you turn left onto Bowen Mountain Road and you will see an intersection about 50 - 100 metres up or so you go past this intersection and you will see the road start to slope downwards, go down this hill about 50m then turn around and face your car back in the direction you came from turn the car off and leave it in neutral then run back up the hill and if your in the right spot the car will slowly start to roll up the hill towards you gradually picking up more speed,
Just make sure you keep a lookout for any cars coming towards you and make sure someone stays in the car to jump on the brakes incase the car rolls off into a fence or something because your in the wrong spot.
Its about 40 - 50 mins from where I live (Mt Druitt area) It only takes you about 5 - 10 mins from Richmond or if your in Penrith you could probaly get their in about 25 minutes.
Directions
The Richmond Magnetic Hill is located on Bowen Mountain Road in the Township of Mountain Bowen, just east of Richmond. The hill is located at the Mountain Bowen Rd. and Westbury Road intersection. It only works for about 50 metres going uphill.
Directions from Sydney
From Sydney City, Take the Harbour Tunnel or Harbour Bridge, follow the Warringah Expressway straight through to Lane Cove, and follow through onto the M2 Motorway right to the end till the Blacktown Exit - Turn right onto Burns Road which follows onto Old Windsor Road, which runs into Windsor Road, turn right and it will take you right into Windsor. In Winsor make a right turn onto Winsor Richmond Road (40) and it will take you to Richmond. In Richmond 40 becomes Kurrajong Road. After crossing the Hawkesbury River in North Richmond turn left on Grove Vale Road. Then turn left on Bowen Mountain Road. The Magnetic hill is on Mountain Bowen Road as soon as you pass the intersection with Westbury Road
Whereis is your friend click here
I might go back their tonight to show my GF so if I do I will take my camera and try record it im not sure how well it will turn out though as its pitch black around their at night.
This post is uselss without Video
Well if its not good enough for you go make one yourself :(
Just yeah if anyone goes play around with it for a while to make sure your in the right spot etc coz if your on a different angle or something it can look completely different and not work so just try a few different areas first.
    • I'm seeing torque specs all over the place for the OUTER tie rod, but none for the INNER tie rod, where it connects to the steering rack. Even in videos, people are just tightening em up as much as they can with a wrench and that's it. Anything tightened down without torque makes me nervous. Anyone know what the spec is for it?
    • Hope you had a great time here in our tiny country.   The JDM scene we have here is quite small, it's mostly BMW, Volkswagen with burble tunes haha. But the few JDM cars we do have in the scene are pretty nice. Some of my friends drive cool s14's too. Both built engines, red one makes abt 500, blue one abt 400 i think?
    • Ye good idea , would have never thought of something like that. Might aswell do it to every pulley and the balancer while I’m there
    • Use an LS1 or similar, via kit like Frenchy's. But.... It's probably not the alternator. It sounds like belt squeal, which would be because the pulleys are glazed. Rub every groove on the pulleys with 120 grit paper. Report back. Oh, and new belts afterwards too. The old new ones will be shitted up already.
    • Hello all I have 2 r34 sedans , one turbo one na, only recently aquired the na 34.  Man what is with these things.... My turbo 34 started sounding like a super charger, it was screaming at anything above 4000rpm , I took the alternator apart and replaced the front bearing which is the only one I think you can access and it did not fix the issue so presumably the bearing in the rear of the alternator is gone. ( diagnosed it was the alternator by taking off the aux belts one by one to figure out which pulley or bearing it was )  My friend gave me one he had lying around, Installed it , it did not squeal for maybe 500kms and now its started to squeal again briefly on startup  Recently got an na r34 and I replaced the timing belt, water pump + all the auxillirary belts. Runs amazing but it suddenly developed the same squeaking problem but significantly worse, Ive had my neighbour come down screaming at me because it was waking her up everytime I moved the car. It takes a good 2 minutes before it quietens down.  Im yet to diagnose where its coming from but im fairly sure its coming from the alternator aswell. My question isnt about how to fix it but rather where can you get a new alternator for an rb25 neo??? Ive searched everywhere but I havent been able to find a direct fit oem type replacement thats not genuine. All the automotive stores sell an oex one - BXA035 - which I picked up for cheap through a friend with staff discount , got it home only to find the connector is completelty different.... As far as im aware bxa035 is for rb20/30's and after a bit of figuring out the bxa035 has an ev14 type connector, which is tiny compared to the rb25 connector. I actually had an ev14 connector lying around which I was considering just replacing the bigger plug with to get the alternator working but the bxa035 is rated for 70amp vs the rb25 alternators are 90amp ( or so ive been told ? ) That paired along with the fact im about to install an amp + sub in the back and I have the stock sized small battery Im not sure itll do the job unless anyone has another opinion?  I know and have seen all the websites selling the ls1 alternator conversion kit but I am not going down that route, nor do I have the money to. Hopefully I can figure out how to get 2 brand new alternators for both cars. I would buy second hand which there seems to be many of but considering how common this seems to be im sure If I installed a second hand one it would start squealing in no time  Or even better if anyone knows how to fix the issue directly with the alternator itself... Any input appreciated Thank you     Link for bxa035 connector picture
