howdy selling my r31 s2 sillo.
DETAILS:
5 stud conversion
big turbo on high mount manifold
brand new button clutch
new reco gear box with heavy duty bearings and short shifter
reco diff disc to disc with spool
front mount cooler with foward facing plenum
new suspention bushes right through with pedders suspension (2years old)
r32 GTR rotors and calipers
vailside ecu
strut brace
up graded fuel system
boost and temp gauges
sports wheel
clear indercators,
s3 front bar and r31 house front lip (everything is colour coded) white same as car
tinted windows
3" mandrell bent custom exhaust
38mm external waste gate with screemer pipe
car has made 207 rwkw @ 18 psi
PRICE: $8500 ono
CONTACT:
Russ for more infomation on 0409027723
EDIT: Russ if you can give some more info on a few things like: big turbo (brand/make) size and age, what button clutch is it and its pressure rating, what upgrades to the fuel system has been made, pump, FPR, is the ECU stock or chipped/remapped then you wont have 1000000 questions asking about them :no:
Also if you have some pics post it up as a mate is keen already :(
GMB
https://www.sau.com.au/forums/topic/150086-fs-r31-sillo/
DETAILS:
5 stud conversion same as r32
big turbo on custome high mount manifold garett t3/t4 custome specs built by me [bush bearing]makes boost from 2g through to the limitter.
brand new button clutch 5 puck ceramic 1200kg clamping pressure
new reco rb20det gear box with heavy duty bearings and short shifter
reco diff disc to disc with spool 3.9.1ratio
front mount cooler with foward facing plenum [built by me as well]
r32 GTR rotors and calipers std aussie struts
vailside ecu modified std one to suit 20psi 8300rpm limitter
strut brace built by me
up graded fuel system 400lph pump
boost and temp gauges 7 colour changeing
sports wheel
clear indercators,
tinted windows
3" mandrell bent custom exhaust no cat or mufler strait 3''
16'' wheels good tyres
car has made 207 rwkw @ 18 psi would make more if you use bigger injectors[idont need to push it to the edge as i wanted to keep it safe for the engine]
will sell with std turbo if wanted [fitted],will reduce price to suit if needed!made 170rwkw with std tbo fitted @ 15 psi
PRICE: $8500 ono
CONTACT:
EDIT: Russ if you can give some more info on a few things like: big turbo (brand/make) size and age, what button clutch is it and its pressure rating, what upgrades to the fuel system has been made, pump, FPR, is the ECU stock or chipped/remapped then you wont have 1000000 questions asking about them :)
Also if you have some pics post it up as a mate is keen already :)
GMB
if i knew how to put pics up i would lol [come and have a look] Edited by 31r
https://www.sau.com.au/forums/topic/150086-fs-r31-sillo/#findComment-2802087
    • The way they do the test you would be very lucky to ever hit any cell that isn't aiming at 14.7 This was my result... Really not sure what's going on there!
    • I have a projecta one.  A proper trickle charger can be left attached 24x7, that's what the trickle bit is about.
    • With an electronic boost controller, there are settings available to limit overboost.
    • Ah ok, my tuner did adjust something on the percentage cycle on the boost controller, instead of running at 40% the tuner put it on 20% to compensate for the overboost, can't remember what it was. Not duty cycle don't think, and told me if it keeps overboosting, it's going to be something else. I think he mentioned the turbo actuator.
    • Which trickle charger does everyone use? I'm going on holidays in the future, and last time it was left for a couple weeks off twice per time, and don't want to keep doing it to damage my battery so looking to have something hooked up to the battery which connected to the car, as I need to keep my immobiliser system on. If the battery goes flat it will mess up my security system (already happened once) I was looking at the following, so can have someone turn it on every couple of days and run it overnight then turn it off)   https://www.supercheapauto.com.au/p/noco-noco-genius-5-battery-charger-6v-12v-5-amp/648987.html?cgid=SCA01060203#srsltid=AfmBOoq4kzQgrm1YHSZT0DzaCwVwwOcevgu0TSDcUvrNeOqI-0S5xJ1C&start=1   https://www.supercheapauto.com.au/p/century-century-cc1206-xli-12v-1-3-6a-9-stage-battery-charger/693006.html?cgid=SCA01060203#srsltid=AfmBOoq4kzQgrm1YHSZT0DzaCwVwwOcevgu0TSDcUvrNeOqI-0S5xJ1C&start=30   though these don't say anything about trickle charging, don't want it to overcharge the battery.
