Maybe they were just having a bad day?
I know sometimes a bad day can make a huge dif in the way you drive.
sure they were being dick head's but we all are at time's
We do all own sports car's even the best driver does the wrong thing sometimes.
PS: I always indercate... I cant help it i feel wrong not doing it 0_o
He must have a bad day everyday, spotted this joker TWICE last week doing the same thing...
Phatboi I may just take you up on that offer....
  • Replies 85
your first claim was that he was so close you couldnt see his bonnet. now you couldnt see from his headlights?? im thinking if you couldnt see his bonnet his lights would obviously be obstructed by the rear of your car. you better get your stories straight before calling the cops next time.
hahha :)
I didnt cause anything, and I didnt do anything wrong. The law says you must have sufficent room on the vehicle infront of you to react to anything that may occour. If he decided he wanted to get so close he could reach out and feel up my ass, be it on his head the consequences if I decide I want to slow down.... I was worried about cops and this guy was trying to push me to go faster. Also, I couldnt see shit from having his super-bright blue lights in all my mirrors.
Id do it again in the same circumstances. I cant fkn stand ppl who tailgate me... Whats more, it was what, 3 lanes in the middle of the night, we were the only cars on the road, there was *NO* reason why he couldnt go around me... So stuff him.
Edited by trig
hahha :sleep:
Okay keyboard-warrior, shall we argue pedantics?
Lights have glare, and I have three mirrors. Even tho he was right up my bum, the glare (not to mention the fact that the light was reflecting off my car, then back off his) was pretty fkn blinding, and I was getting the full blast of them through the side mirrors....
But basically what your saying is if I drive right behind you with all my lights on, even if you couldnt directly see my headlights, your saying you couldnt see the light they generated at all, what so ever, in any way shape or form, correct?
oh, welcome to the forums btw....
Hey hun :kiss: just woke up, having a shower now then ill head right over :)
    • There are a few different ways of doing it. I'm currently running two 1000cc pre-TB nozzles and PWM the pump for control. I'll be moving over to a constant pressure system and direct port. I'll run the pump off a regular relay, have it cycle on roughly 5psi before I start injecting to build pressure and then PWM a WMI solenoid (It's basically an injector that can take a lot of pressure and not corrode with water and meth.) The solenoid feeds the 6 direct port ~200cc nozzles. I'll also keep one ~250cc pre-TB nozzle to help keep IAT's in check.  Safety will be a little different as well. I used to use a pressure switch but will be moving over to a pressure sensor between my solenoid and nozzles. I'll trigger my solenoid and if I don't see specific pressure within a specific timeframe (e.g 100psi within a second, 175psi within 2 seconds), I kill it and revert back to non WMI maps the same way I did it before with 4D in Haltech. I was just figuring out the timers in my ecu last night. They made that a little more complicated than I would have liked... I wish Haltech offered a larger set of logic/math functions like other ecu's do. I can't do very much with just AND's and OR's.  I've been asked to do fuel/ignition mapping on a medium bore engine at work in May (192L V16). Being the only programmer in my region and having went and opened my mouth about knowing the ins and outs of fuel/ignition mapping, I have now been deemed an expert. Fun fun. The entirety of the logic and algorithms are programmed in C on a PLC. As I spend more time figuring it all out, I like what I see and eventually I may consider doing the same as a pet project to replace my ecu.
    • This would be interesting, would you feed it via a 2nd row of injectors? Or just usual WMI nozzles?
    • Cut sump up and extend. Win win 😂
    • All, What's the recommended torque for the 1/2 head studs for RB30 twin cam conversion with RB26 head?
    • also, we need to know which solution worked....
