Maybe they were just having a bad day?
I know sometimes a bad day can make a huge dif in the way you drive.
sure they were being dick head's but we all are at time's
We do all own sports car's even the best driver does the wrong thing sometimes.
PS: I always indercate... I cant help it i feel wrong not doing it 0_o
He must have a bad day everyday, spotted this joker TWICE last week doing the same thing...
Phatboi I may just take you up on that offer....
  • Replies 85
your first claim was that he was so close you couldnt see his bonnet. now you couldnt see from his headlights?? im thinking if you couldnt see his bonnet his lights would obviously be obstructed by the rear of your car. you better get your stories straight before calling the cops next time.
hahha :)
I didnt cause anything, and I didnt do anything wrong. The law says you must have sufficent room on the vehicle infront of you to react to anything that may occour. If he decided he wanted to get so close he could reach out and feel up my ass, be it on his head the consequences if I decide I want to slow down.... I was worried about cops and this guy was trying to push me to go faster. Also, I couldnt see shit from having his super-bright blue lights in all my mirrors.
Id do it again in the same circumstances. I cant fkn stand ppl who tailgate me... Whats more, it was what, 3 lanes in the middle of the night, we were the only cars on the road, there was *NO* reason why he couldnt go around me... So stuff him.
Edited by trig
hahha :sleep:
Okay keyboard-warrior, shall we argue pedantics?
Lights have glare, and I have three mirrors. Even tho he was right up my bum, the glare (not to mention the fact that the light was reflecting off my car, then back off his) was pretty fkn blinding, and I was getting the full blast of them through the side mirrors....
But basically what your saying is if I drive right behind you with all my lights on, even if you couldnt directly see my headlights, your saying you couldnt see the light they generated at all, what so ever, in any way shape or form, correct?
oh, welcome to the forums btw....
Hey hun :kiss: just woke up, having a shower now then ill head right over :)
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
