im in the stages of painting my rocker covers . and i was thinking of doing the cam cover , i wanted to know will the paint be able to hold on this?
also the black coil pack cover? could that be painted with the same stuff even though its plastic - or would it eventually just peal off cause its not metal?
cheers
https://www.sau.com.au/forums/topic/150105-cam-cover-paint-question/
you will want to work out if you want it smooth or not, currently they are not, if you want it smooth then a primer will be required to fill the gaps
sand that back and apply paint (using a primer/filler in a can wil ensure it is primed sufficiently)
cam gear cover is metal thats painted, 400 wet dry and paint straight over it
primer and paint stick to plastic without issue, may not be completely scratch resistant without a primer though
alright thanks for the help guys . i will use some primer on the plastic coil pack cover , and sand it to 800 gritt wet n dry which i did with the rocker covers .
also i wanted to ask is the cam cover hard to remove?
remove the crank angle sensor
then undo the 5 bolts holding the front panel of the cam gear cover. be sure to mark where the CAS is set at so you can put it back to the original settings
  • 3 months later...
isnt this pointless as you end up spraying over your marks anyway?
not really, as i would be taping up the rubber section so as not to paint over it, always looks tacky if people paint over this area - as its rubber and the paint peels off ..then you run the risk of if flaking off the main panel as well.
umm you should remove the rubber piece (it slips out). tape on out side to show the position, make the small mark on the inside, paint it. When dry put a piece of tape on the outside corresponding where the inside mark is. that way when you refit it all you have to do is remove the tape, if it is dry no probs :laugh:
i got high temp engine paint, as im doing cambelt cover, cam covers and plenum, should i still use primer and clear?
used 3 good coats of primer, about a 7-8 coats of colour and 2-3 of clear,
PREP WORK GUYS!
my finish is very let down by the preperation time, used a 200 grit to rough it up, a 320 to smooth it, a 800 to ready it for primer, a 2000 after primer before paint (wipe down thoughly every sand too!!) and long even strokes of paint finishing the spray OFF the item
    • As strange as this sounds (as they are fixed back), my Bride Xero CS seats are the most comfortable seats I've used.  I vote go genuine.  The only downside I've found is on very long drives, you can't reposition your body while driving. So even though its comfy, being locked in the same position eventually becomes uncomfortable. I find myself stopping every 3 or so hours to stretch my legs on long drives.
    • You don't have to be bored driving a Camry. Not based on the way that a couple of f**king Ubereats/Didi/othersortofmethaddlednightshiftattheservicestationrecentimmmigrants were piloting them on the way to work this morning. f**k me dead!
    • FWIW, the Bride reps are really nice to sit in. The only complaint I have, other than the tear in my bolster, is that the velcro used to hold the backrest cushion in place, up under the headrest, is a little obvious and intrusive and could probably be done better. I don't know if that is a "feature" on the genuine ones also though. I haven't looked at a genuine one like the ones I have, only some of the older models. The other thing is, even though I bought the CF ones, I think the CF is really just decorative, over the top of the same FG as the normal seats. And so they really aren't light. Between the solidly built CF/FG seat, the steel frame in the recliner mechanism, and the solid-arse seat rail, they are probably heavier than even the stock seat. They are a serious lift to get in and out of the car.
    • Yes, and so the barest minimum power target is the one that makes the most sense. Massive power is fun, but you can only use it for 1.5s at a time, and only every now and then. Medium power levels allow you to enjoy the car far more often and for longer. 500 engine HP is just below 300 rwkW which is about the maximum that is sensible for any street car really. And for a 2.6L six, it will still leave you with a decent boost response and some sort of linearity of power delivery. As you get up towards 400rwkW the onset of power tends to be increasingly like a cliff and you need drag radials to keep the ground in proper contact with the car, and.... it's just not a car for driving around any more.
    • I already reached that conclusion myself after reading up a whole bunch and watching various videos from multiple sources. Don't know yet how I'd best manage that with the least amount of headache. Probably pulling the sump and just welding on a AN10 adapter or something. I also think it's healthy to take most opinions with a grain of salt, because experiences differ wildly and especially Aussies - when talking about RBs - don't know a world below 600whp drag builds. Personally I doubt I will ever take my R33 racing, so it's going to be a street car with the occasional spirited drive. Hence why I am (so far) under the impression that I'm going to be fine with a stock-ish engine for a while.
