im in the stages of painting my rocker covers . and i was thinking of doing the cam cover , i wanted to know will the paint be able to hold on this?
also the black coil pack cover? could that be painted with the same stuff even though its plastic - or would it eventually just peal off cause its not metal?
cheers
https://www.sau.com.au/forums/topic/150105-cam-cover-paint-question/
you will want to work out if you want it smooth or not, currently they are not, if you want it smooth then a primer will be required to fill the gaps
sand that back and apply paint (using a primer/filler in a can wil ensure it is primed sufficiently)
cam gear cover is metal thats painted, 400 wet dry and paint straight over it
primer and paint stick to plastic without issue, may not be completely scratch resistant without a primer though
alright thanks for the help guys . i will use some primer on the plastic coil pack cover , and sand it to 800 gritt wet n dry which i did with the rocker covers .
also i wanted to ask is the cam cover hard to remove?
remove the crank angle sensor
then undo the 5 bolts holding the front panel of the cam gear cover. be sure to mark where the CAS is set at so you can put it back to the original settings
  • 3 months later...
isnt this pointless as you end up spraying over your marks anyway?
not really, as i would be taping up the rubber section so as not to paint over it, always looks tacky if people paint over this area - as its rubber and the paint peels off ..then you run the risk of if flaking off the main panel as well.
umm you should remove the rubber piece (it slips out). tape on out side to show the position, make the small mark on the inside, paint it. When dry put a piece of tape on the outside corresponding where the inside mark is. that way when you refit it all you have to do is remove the tape, if it is dry no probs :laugh:
i got high temp engine paint, as im doing cambelt cover, cam covers and plenum, should i still use primer and clear?
used 3 good coats of primer, about a 7-8 coats of colour and 2-3 of clear,
PREP WORK GUYS!
my finish is very let down by the preperation time, used a 200 grit to rough it up, a 320 to smooth it, a 800 to ready it for primer, a 2000 after primer before paint (wipe down thoughly every sand too!!) and long even strokes of paint finishing the spray OFF the item
    • All of your suspension bushes/bolts etc, should also only ever be tightened when the car is sitting with full weight too.   IE, jack it back up, shove a heap of stuff down so you can lower the wheels onto so the car is "on the ground" but you have room to get under it.   It's why when properly done, you should be able to remove the shock and spring, but the arms won't go to 100% droop. If you don't do the above, you'll destroy your bushes.
    • We have some more genuine Japanese legally decommissioned car number plates in stock 🙂, as well as the plain white 40mm hole cover: Tama 400 No 12-41: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-no-1241 Morioka 300 Te 43-58: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-te-4358 Plain White 40mm Hole Cover: https://www.oemsoko.co.jp/products/genuine-japanese-vehicle-number-plate-40mm-hole-cover-white There's also a yellow plate for Kei cars with the corresponding yellow 40mm hole cover sold as a set: Tsukuba 581 Ii 64-66: https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-single-number-plate-ii-6466 Also some Skyline 1/43 scale models: 1989 BNR32 Nissan Skyline GT-R (Silver): https://www.oemsoko.co.jp/products/rare-ebbro-oldies-2006-release-bnr32-nissan-skyline-gtr-silver 1989 HCR32 Nissan Skyline GTS-t Type M (Red): https://www.oemsoko.co.jp/products/kyosho-original-1-43-hcr32-nissan-skyline-gts-t-type-m-red
    • These arrived today! Sadly I'm going to probably be smart and enjoy the car as is over the summer/sunny period and save the ~2 weeks downtime it'd take to swap the heads over and tune later in the year. Maybe. It's going to be pretty damn tempting seeing these bolt on funs just sitting in storage when they're ready to go. There's a non-zero chance I end up @The Bogan'ing it.
    • MZ11 Toyota Soarer in Iwata, Higashi Osaka
