  • Replies 64
Go and check out Phantom motors at Stafford on the corner of Stafford and Webster Rd heaps of 4 doors there.
been past there already. plenty of 34s no 33s I could see..
Well you're already ahead of many first-time Skyline buyers, just by being on these forums *before* you buy the car. And it's not like you don't know 33's :mad:
that part is mostly taken care for due to revhead and his old 33 coupe.
Ooh nice. So am I in trouble? :(
need auto though. tried to get her to drive manual (both vans are manual.) she won't
You could use that to your advantage though... :) lol
You can always have a look at mine at some time, its a series 2 aswell so it would be a good comparison for your wife. There a some major differences in the series 1 and 2 sedan, the biggest one being the battery has been relocated back under the bonnet giving much more boot space.
Some pics can be found here :
http://www.skylinesaustralia.com/forums/in...howtopic=147957
I also have access to another series 2 sedan in silver if you wanna compare colours :(
I am not one for beating around the bush so my only advise on the topic of convincing the missus to go with the Skyline is "Skyline or divorce".
If she leaves you then you can get a R34GT-R after you sell everthing during the split :huh:
Jokes.
For years my wife was NOT in favour of me getting a skyline.
2 doors... they're just not a family car!
I took her for test drive, when we got back to the car yard, she had a silly grin & was looking for the cheque book!
A week later she found a 4door skyline - I told her ALL 4doors are non turbo and aren't as fast.
Yes, a small white lie, but it worked!
I think I used the same angle with the Auto vs Manual - it worked!
yes dear, they are very economical, parts are easy to find...
it does down hill from here
Well I showed Chris my sedan and now all we have to do is pray to the skyline god that she lets him go ahead with the purchase. Good luck Chris.
this is fun. she drove a camry afterwards.. trying to tell here that the distance from the front of the rear seat to the front seat is the same as the camry.
(worst goes to worst I'll buy the car anyway!!)
If she leaves you then you can get a R34GT-R after you sell everthing during the split >_<
Jokes.
hehe! gtst coupe would do me fine.
that side I have gotten past. its the newborn in the backseat of a 33 that she doesnt quite follow. to me its a car (alright toy >_< ) and she likes the noise and the push in the back insuance is damn near teh same as the starlet for here so I really don't see what the issue is.
I'm going to keep working on this :O
I also have access to another series 2 sedan in silver if you wanna compare colours >_<
address/contact details pls. (PM)
resort to their tatics...
buy something, hide it for a few weeks,
when asked, comment; 'that old thing, I've had it for ages' >_<
don't even mention a camry - if she opens the boot (where the pram goes), it's all over.
too late..
though I'm not giving up.
Do what I did when I got the 34...
Took her to the caryard after hours to look at the car...she liked it but didn't say buy it...
A week later, bought it, picked her up from work and suprised her...no turning back :cheers:
thats what I'm thinking - however the car is in japan.
    • Updating results following our SR20det project. Data collected form improves future turbocharger making and high flowing services. So far differences between G and GT series turbine wheels, we are in the process of making a new turbine, the aim is for better mid top range flow without gain too much lag.  Result is back to back comparison of G25-660 and GTX2867 spec turbochargers on the same car, nothing changed apart from turbocharger. Both tuned to knock limit from pump 98 fuel (US Ron93). GTX2867 was about 400RPM more responsive making 255rwkws while G25-660 made 17 extra Kws with wider spread of torque after 4500RPM finishing off at 272rwkws.
    • @GTSBoy i tried to jumper the wires and got the steering wheel light to come on which is right under the gear indication but that still doesnt come on.  Can it be an issue with my cluster?
    • Given that you have seen the dash indicator work briefly, then it would seem like you have a simple wiring problem. What happens when you simply jumper the wires on the "steering wheel switch"?
    • Yesterday's day in review: All the wiring to the lights up the front how I want it, is ran, terminated, and all to length. The only lighting up front I haven't finished is the side indicators, as I need to get to the partly cutup factory loom, and find the plugs for them. Interesting note, the side indicators use the exact same plug that's in the doors for something else that I don't remember what it is... So that plug better be careful...   Power steering solenoid, on the R33 is variable, and from memory PWM. The Ford's control from the docs I have so far, is it's just a on or off control. So I'm not sure it's what I want, and in any case, power steering running, but at its heaviest (solenoid off) is likely what I'll want anyway, so I'm not yet touching it at all. All the wiring I can complete so far, is done. There are 3 wires I need to make a plug for at the ECU, and these are just for the vehicle speed sensor, of which I need to get a T5 from an AU, so I can use its output that has the speed sensor on it. (My car doesn't have ABS, otherwise I'd set it up to use one of the ring gears on that). I need to buy new headlight globes and front parker globes, otherwise I could show photos of lights working. Current fuel lines in and out on this motor are "5/16". I'll order hardline, and some AN fittings for that, and I just need to 100% check fuel line size at the tank end, to get the ends for it. I'm also looking at a few options for the banjo bolts to AN fittings for the power steering rack. I'll pull the reservoir off the Barras PS pump. There's an off the shelf fitting for that pump for a -10 AN feed, and it'll use a 16mm to dash -6 an outlet to feed the rack. I'll be making my own power steering reservoir, I'm going through the thought process at the moment of how I'll run the baffles, and I need to research another idea for it too.
    • Two inlet runners changes the engines characteristics requiring less fuel to make torque at different points in the rev range. The smaller diameter inlet runners on the DET increases air flow speed, which improves atomisation of fuel, particularly in low load/idle for better burn, and in specific areas of the engine, (areas you would use when driving normally) increases the efficiency. All of those items change how efficient the engine is at different speeds. The changes on the neo help slightly to improve emissions where it matters. The overall improvements won't be the likes of going from an engine built in the 70s to an engine built in the 2000s, it's just a small step. But still leaves it the RB with the best chance of improvement.   As for your comment about the whole using a cat to not need to worry about those gases. Two things, no system is 100% perfect. It won't eliminate everything. So reduce the quantity you put into it, you still reduce the output. Two, make that system do less work, and it's likely to survive a little bit longer. Funnily enough to, one trick employed to get cats up to temp, AND to drastically reduce emissions before they get up to temp, is to reduce ignition timing.
