why is it when i squeeze the throttle to build boost (only a little) then flatten it it seems to go so much better than when i flatten it straight away...???
is it because it may be pumpin mega fuel too quickly and boggin it down than when i let it breath a bit before gunnin it? it tends to pull so much harder when i let it build pressure first especially in the mid to top end rev range.
also....
sometimes the boost can climb all the way to 1 bar....i am using a bleeder valve and am full away of spiking etc..this aint spiking..this goes straight to 14 pounds which is straight past the 10 pounds its set at. This is at random intervals in random gears....its doesnt flat spot either...like most rb25's do. it actually goes quite well.
https://www.sau.com.au/forums/topic/150172-explain-me-this/
again with rich and retard.0 grrrrrrr no!!
much like your dyno graph is the best way to explain it.
instead of your engine making say 50rwkw at like 2k and slowly coming up on boost and making your power what ever it is..
your not letting the engine "start" to make power instead your skipping the frst half of the dyno graph and going from say 50 instantly to 200 say..
as well as you efectivly giving it anitlag by throttling it then flooring it lol.
https://www.sau.com.au/forums/topic/150172-explain-me-this/#findComment-2798139
gotta love this forum. the moment there is a hesitation problem everyone say rich and retard. if it was R&R he would have it in both situations. he is stomping the gas in both situations, just in one he gives it light throttle for a few hundred rpm then stomping it.
where do you have the bleeder valve getting its reading from? is it a hose that gets vacuum as well as pressure (such as the bov hose) or if it just off the cooler piping. i was getting spiking after my intercooler instal as i had the booct controller getting its reading from the bov hose. i put a nipple into the hot cooler pipe (from turbo to cooler) and this solved my problem.
https://www.sau.com.au/forums/topic/150172-explain-me-this/#findComment-2798184
I used to do something similar with my V8. If I eased the pedal with the revs, it would speed up much more quickly rather than if I just planted my foot down.
I'm still testing with the Skyline, and I think I feel what you are feeling... but not as obviously.
Two thoughts...
1) Perhaps it just feels better because you're already moving some speed before you hit the pedal, and the sudden burst feels stronger?
2) Possibly this could have something to do with the maps in the ECU? You'd be on wide open throttle (TPS sensor), but at a low rev-range, and the AFM would be reporting whatever air it is currently building up. So at a guess there... perhaps your low-rev, high TPS areas of the ECU are rather rich and/or timing is quite retarded at that point?
Dunno... i'm still trying to work out in my head whether this is myth or fact... whether it's a perceived feeling, or an actual difference.
https://www.sau.com.au/forums/topic/150172-explain-me-this/#findComment-2799789
yea thats what im still figuring out....i had this problem with my last rb25det....
im just putting it down to when i stab the throttle straight up its pumpin the juce in richening it up more than it has to and boggin it down a tiny bit. where as if i let it kinda free rev with 0 VAC its cleared all the 'dead' fuel and its ready to GO....because i feel a NOTICABLE difference.
https://www.sau.com.au/forums/topic/150172-explain-me-this/#findComment-2800131
its all an alusion people.
and can someone please explain to me wtf this rich an retard retared explination means?
is the a diagnostic flowchart for this strange problem. or did someone just give up on a issue and come up with this stupid explination.
seriously. take your car to a workshop and tell them "oh can you fix my r and r problem " theyle shut the door and laugh a you lol.
do we have a timing light and air fuel meter hooked up to confirm this issue?
were all aware that if the engine knocks/pings it pulls the tiing back?
aaaaanyway. the only true way to tell is a back to back test on a dyno and plot the two graphs :D
bottom line is theres nothing wrong with your car.
https://www.sau.com.au/forums/topic/150172-explain-me-this/#findComment-2800190
the stock ecu has excess airflow protection, that is, it will protect itself if too much air is coming in via the airflow meter. this is usally assocaited with someone fitting a boost controller & a bigger exhaust or a combination of either.
the stock ecu has a ramp for what it considers is too much airflow for a given RPM range and if it (afm voltage) exceed's this value it kicks the timing out the window and runs mega rich. the ecu assumes something is wrong and backs off timing/afr to protect itself, hence the name "excess airflow protection". its other names in "boost cut" or "rich and retard" as simply thats what it is.
https://www.sau.com.au/forums/topic/150172-explain-me-this/#findComment-2800251
Sorry to interrupt
but im havin similar issues, with slightly putting my foot down at 100
comin under load, and jsut creepin into positive boost
that my car starts hesitating, and feels like compressed air build up and then unloads the air back through the propellers through the turbo.
and jerks.
its comin down that i f@#kin hate drivin my car,
other then that ya flatten ya foot and it pulls hard as.
I have noticed it in 4th and 5th.
And have only noticed it since i had a tune with my pod air filter install, 550cc inj, fuel reg, and upped boost to 18psi.
Anyone have similar problems, im goin to get my car tuned soon. see whats happenin
https://www.sau.com.au/forums/topic/150172-explain-me-this/#findComment-2800434
and please dont say anything about the turbo
as its not stock, its hiflowed and had been runnin at that pressure for couple of months and is awesome, have checked the play in the wheels recently and is the same as when i got it rebalanced and cleaned.
currently running 320rwhp but have restriction on standard actuator and only goes to 15psi
https://www.sau.com.au/forums/topic/150172-explain-me-this/#findComment-2800441
basr33 your getting compressor surge. quite common on highflows still using a smalish exhaust housing.
its heaps anoying.
fitting a factory tension blow off valve and plumbing it back should fix it.
although my gtr when it was stock used to do that heaps hard on the freeway. peoply crusing past me looking at me as my car sounds like zoidburge. heaps funny but
https://www.sau.com.au/forums/topic/150172-explain-me-this/#findComment-2800463
i have a turbosmart type 3 blow off valve
would you be able to explain what a factory tension blow off valve is
cause from lookin at it, it sounds like it nothing to do with the turbosmart one.
is it one thats on the turbo itself??
Any help is much appreciated
https://www.sau.com.au/forums/topic/150172-explain-me-this/#findComment-2801394
compressor surge actually occurs when the pressure past the compressor outlet is greater than what the compressor can actually supply. that is, for example if the compressor map dictates that in the best possible turbine speed it can flow say 12psi of pressure and you are actually getting say 14psi. the compressor is forced to a speed beyond what it can supply in a stable state, so the compressor wheel surge's.
it usually sounds like turbine or compressor wheel flutter as its coming on boost (vl turbo zzztttt ttt tttt tttt noises). you should discuss this with the place that supplied the turbocharger hiflow and do a few simple checks on your car setup. look for leaks, fouled intake tubes/pipes/clamps. check the bov setup.
https://www.sau.com.au/forums/topic/150172-explain-me-this/#findComment-2801442
way to hijack....
MY CAR ISNT DOING THE RETARD TIMING- RICHEN UP SAFETY SHIT!!!!
do you NEED me to repeat that..i know what that is and its not that.
I will repeat what i am DISCUSSING! not complaining about!
I PULLS HARDER FROM 2000 RPM to 6800RPM when i feather throttle to 0VAC to 1-2psi and squeeze throttle. RATHER THAN having it on 15VAC and STAB the throttle!!!! pull so much harder its noticable. all the way to redline WITHOUT any flat spots.
https://www.sau.com.au/forums/topic/150172-explain-me-this/#findComment-2801654
i'll give this a go...
to put things simple
at lower revs when engine doesnt require that much intake air, with throttle fully open, airflow will be slower than throttle partially opened
so thats why, say for arguments sake, on 3000 rpm, full throttle will be slower than 50% throttle
at higher revs, the throttle will need to be fully opened so that the air flow can catch up to the engine speed
so progressive throttle will always be faster than flooring it when accelerating from lower rpm, this gets more apparent in a taller gear
but yeah, not good flooring the car in lower rpm, it just stresses the engine
ecu will dump more fuel and add timing -- doesnt promote torque either
Edited by chiksluvit
https://www.sau.com.au/forums/topic/150172-explain-me-this/#findComment-2801778
    • Rotisserie is fully assembled apart from centre connector which obviously isn't required until the car is on it. It packs away fairly neatly and doesn't take up too much room. (Now that I actually have some room after my clean up!) Overall very happy with the quality of it.  Assembly was a piece of piss.  The only thing I didn't like was that the pins that lock the rotation lock wheels in place were a bit of a dick in a bucket scenario. It allowed the arms to rotate a significant amount even when locked in place.  To fix that i measured up the hole and went and grabbed a couple of 18mm fully threaded bolts and a thread tap to suit. I ran the tap through top and bottom so it was threaded both ends.  Then just threaded the bolt through both sides.  It has made a massive difference which hopefully you can tell in the before and after video how much difference it made. 20250207_161431.mp4   20250207_161431.mp4 Hopefully back working on the car over the next few weeks.   20250207_162801.mp4
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
