  • Replies 40
Well done man. I bet that makes all the late nights working on the car after work worthwhile now?!
Reece's car is in a totally different catagory. Bloody lightweight, stripped out race car on slicks with a HKS2.8l egine. Theo's rocket is a full weight, full interior(except stereo and back seat) street based car on street radials running the factory 2.6l crank/capacity.
Keir Wilson's street radial time is well within reach now. 8.89 at 160 at jambo a couple of years a ago with an OS 3.0l and much lighter car as well. I take it that is the next nymber you are chasing hey?!
rec 0.432
60 1.427
330 3.859
660 5.853
mph 124.24
1000 7.542
ET 8.957
mph 159.86
kph 257.27
genuine congratulations theo.
it will be nice to see that 60 foot drop with the slicks.
159 mph is quick, proves its making good horsepower.
reaction is good too.
hopefully you can take this into competition and gets some wins on the board.
shane >_<
big marky J will be back for the grabbing , but big congrats
The fact that Mark tuned the car for Theo this time shows the sort of bloke Mark Jacobsen is and an example of the friendly rivalry in the sport, no cloak and dagger stuff you find in other forms of motorsport. These two guys (theo and mark) are so approachable and the first ones who will be around to give a bit of advice and share the knowledge they have.....top stuff fella's.
    • 1. Factory knock sensors for now, honestly the RB26 OEM knock sensors seem ok as they're flat response instead of resonant type but they appear to be internally grounded to the block. If I do replace the sensor it would just be to get ones that are not internally grounded so a differential input can be used to reject common mode noise. Definitely plan on fixing this as a part of the tuning process. 2. Never deliberately induced knock, though I guess I could try that experiment if I really wanted to. 3. All of this is basically on a stock engine + ECU, only modification is HKS GTIII-SS turbos and a Nismo plenum. Currently I run it with the wastegate solenoid unplugged so it won't try to raise boost past wastegate pressure.
    • After being peer-pressured into paying $100 for the MW remakes, got BO6 on XBox Game Pass. I think that's worth it.
    • That's a given!  Bit hard to powdercoat it properly without removing them! 😁
    • No detail on compressor or turbine sizes, which doesn't help with housing size selection with that kit. However, from SR20DET mucking about and money torching perspective, a GTX2860R Gen 2 w/ 0.64 (46mm inducer) will do ~260kW on E85 about 1.5bar of boost. All in before 3000pm, which cause a gearbox to shatter. Now imagine the same turbo, on a modern motor with an extra 0.5L of displacement, and heaps of cam timing adjustability (not an on/off affair like the Nissan shit boxes). If this was my car (which I would never own or consider buying, ever!), I would go for a nice twin scroll setup, and a G30-660. Gates plumbed back, no silly shit. Lean on the cam timing, big displacement to create a flat-ish torque curve.
