I have a 1994 R33,
I just turn my boost up to 11 pound using a single stage turbo smart boost controller. Since then I am having a problem with flat spots between 4,000 and 5,000 rpm. A mate of mine said that the R33's have factory boost limiters maped into the computers?
An suggestions would be helpfull.
Thanks...
Super AirFlow converter.. by Apexi.. it hooks into the oxygen and air flow meter sensors of the car and into the ECU .. basically a correction factor so the ECU "sees" less or more air than actually going in for each rev range. With a different reading "seen", the ECU adjusts the fuel mapping accordingly resulting in a richer or leaner mixture than factory. This generally can be used to give the car a 20-30% power increase with the right tuning.
Its what you use when you don't have a full aftermarket computer (around $1000 more) where the fuel maps (and other things) can be adjusted internally a lot more accurately. Hope that helps.
Thanks for your reply,
I was going to buy an after market computer. By reading your post above it looks like that will solve my problem.
Ps, Is it true that the standard R33 computer has a over boost restricter? because the problem only exists at 10 pound and over
Hi GunMetalR33, the issues and solutions are;
1. Over boost protection, the ECU cuts fuel and ignition when boost goes over 11 psi. Solution device called boost cut defeater. Cost a couple hundy.
2. 180 kph speed limiter, the ECU cuts fuel and ignition when the speed goes over 18o kph. Solution device called speed limit defeater. Cost a couple hundy.
3. Fuel mixture enrichment, the ECU increases the fuel supply as boost increases. Solution device called SAFC as explained above. Cost a few hundy.
4. Ignition timing retard, the ECU retards the ignition timing as boost increases. Solution device called ITC similar to SAFC except it modifies the timing signal such that the ECU does not retard the ignition. Cost a few hundy.
So if you add all these together you will find that the total cost ends up more than a Power FC. Particularly if you can pick up a used one. If you want to fix all of these issues we always recommend the PFC, if you are happy missing out on more than one fix then maybe the SAFC is worthwhile.
Hope that helps
Andrew (Jayson here :) ),
I was just thinking, it could be the gap in your plugs !!!
Damn, if I would've thought about that last night we could re-gapped them then :P
Seems your car is one of the rare ones that are totally stock, I'd say your plugs are still gapped at 1 or 1.1mm !!
Damn (hitting myself in the head), I should've thought about that !!
Cool, we can re-gap your plug's a little on the weekend and see how it goes?
J
  • 3 years later...
my car was stock.. but shite, after putting on exhuast and fmic... YOU CNT GO BACK !!!, soooOOOo much more efficient, seriously that smic is sooOOO shithouse its not funny....
Sorry I am new to forums & Skylines, what does SAFC mean?
ha ha ha, I cant believe I asked this type of question :)
Its amazing how much you can learn from this forum... I went from "What does SAFC mean" to installing after market ecu, turbo, injectors and clutch etc :)
man, this takes me back to the first couple of weeks that I had the car :)
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
