Yeah glad I didn't take my car as my japspec coilovers would NOT have liked those roads at all.. was just too bad my mate got pissed off and decided to bail after the first meet.. freeway leg would have seen some nice runs but he was having major traction issues with the new streetslicks :kiss:
We barely managed to get a map but I guess the lack of maps was the reason why there was like 50 cars trying to throw ueys on that sketchy bit of Gt Northen Hwy when we all missed Chittering Road or whatever it was (we even had a map and missed it!).
What made me laugh was all the people that came to the church a different way than we did and couldn't see the 20 cars in the dark carpark.. I swear I watched at least 50 cars pulled out and hoon past the church without a clue.. not to mention the Trev's in the v8 commodores lighting it up.. I bet the residents of Bullsbrook loved us :)
I don't even think there was a sign for chittering coz every 1 missed it!! the drive down brookton was pretty dangerous as we were doing between 180+ kmph to try keep up!! poor lil corolla >_<
oh and dont get me started on those kangaroos!
We didn't stay for the brookton bit as the car I was riding in had its' boatspec drag suspension still in.. even the leg out to Bullsbrook was pretty scary.. and the driver of that white 33 with gate that over took us (and the 3 cars behind us) then over took another 5 cars ROUND A BEND was f**kin' crazy! car sounded mean tho >_<
Yeah tiesto I was in that carpark too, I could see a massive queue of cars a street over waiting to pull out onto chittering rd. I was standing under a big light and was a little amused that they couldn't see us.
freeway run owned! was about the only good thing on that night. had heaps of good runs both north and south.
the amount of people i saw over taking in complete stupidity on the outer city roads was rediculous! some people just dont think.
totally agree :(
    • Meanwhile, 20+ years ago, I pulled out the 105mm hole saw and went straight down through the inner guard in front of the airbox to get my stormwater pipe cold air intake in. Right behind the two stock holes for the intercooler pipes. Those have no reinforcement (apart from a couple of robust pieces of steel pipe through them!). I feel that the Australian vehicle standards crews put way too much emphasis on "maintaining the crash performance" of cars and not enough consideration of "any crash is a new and wonderful experiment with a random selection of parameters and you will never be able to tell if an extra 80mm hole through some sheet metal caused a significant difference...but if you close your eyes and squint at the whole structure, engage your engineering brain and have a good think about it, you'd have to expect that it would do jack all."
    • You guys are focussing on the wrong part of this post and have headed off on an irrelevant tangent!  Clearly I'm not going to put my most prized physical possession (well it will be once I'm finished it...) on a piece of shit contraption that might fail and crush me or my car!  At no point was that even implied I was trying to buy a butchered P.O.S that some shonky clown had thrown together with a gasless MIG....  Either way I would love to see the build quality of a rotisserie that has failed.  Actually I'd love to see a photo of one that has failed full stop.  Google fails to deliver.  Never happened?? I'll either make one that won't fail or will buy one that wouldn't fail! End Post.....
    • Yeah, if you can't breathe for more than about 2 minutes, you're cooked.
    • Well, all the power should be getting dissipated across the starter motor. Therefore, ideally, the voltage drop across the earth lead should be convincingly close to zero. Certainly you'd want it to be only a volt or so at max, because otherwise that volt doesn't turn up at the starter to do what is required. A car can probably survive a bad enough earth to crank and start with only 9V or so at the starter motor, maybe even a bit less. But you're seeing only 8V at the battery terminals when cranking, so there can't even be that much available over at the starter, which simply won't do. I would have thought that you couldn't pull enough current (with a healthy starter) to make the battery drop to 8V locally. But I was ignoring the possibility that the starter is in fact crook. If it has shorted windings (or maybe the solenoid is borked and shorting to earth) then I guess it could pull a stack of current and not even look like wanting to turn over. So follow the other boys' reccos too. Because they are just as likely at this point.
    • Depending where the whole gets drilled, and what country/state you're talking about, quite likely not.   Under ole vehicle mod rules in NSW, VSI06 allowed for drilling of holes in "non structural" areas. So you could drill a hole through the inner guard, and not need engineering. You couldn't drill over seams, and it was advised to add extra reinforcing around the hole, as well as something to protect from sharp edges.   Again, it's all about finding the documentation for where the mod is to be done, AND then being able to explain the situation, with the documentation as to why you don't need engineering, with a positive attitude, to any one of the likes eg, police, vehicle inspector, etc.
