Hey guy's, I've recently bought a Blitz front mount intercooler, HKS pod filter and Boost controller for my 33 and I'm wonderin where's a good place to get it dyno tuned and get the stage settings put into my boost controller, and a rough cost. I was also wonderin where's a good place to get it surviced. I'm near the tea tree gully area. Thanx guys
https://www.sau.com.au/forums/topic/150256-dyno-testtune-and-service/
I vote for servicing the car your self.
Send it in every year or so for a check up/power run on the dyno.
The money you save on paying some one else to drop the oil you can then put towards a turbo/ecu and make it a 'real' sleeper; not just another 170-200rwkw r33. :)
Sorry dude, I have already installed them. it's just programmin the boost controller and gettin it dyno tuned/tested I wanna know about. where's good to take it and roughly how much...
I also have a problem where my car if i'm in a line up or something and it's not movin far at a time that it keeps droppin its idle and sometimes even stallin. the only thing I can think of is it might be suckin in to much hot air out of the engine bay. But that's just a guess...
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
