boomtheroom Posted January 6, 2007 Share Posted January 6, 2007 ive searched the site for weeks , but havnt found anyone who has had the 4wd light come on with the 18 flashes on the ets computer (pressure switch and circuit fault) and actually posted a solution to it can anyone who has had this problem let me know ,cheers! Link to comment https://www.sau.com.au/forums/topic/150257-4wd-light-error-r32-gtr/ Share on other sites More sharing options...
T04GTR Posted January 7, 2007 Share Posted January 7, 2007 mayby you need a hydrolic unit. unusual but you never know. is it plugged in and the wiring un damaaged?> Link to comment https://www.sau.com.au/forums/topic/150257-4wd-light-error-r32-gtr/#findComment-2800162 Share on other sites More sharing options...
boomtheroom Posted January 7, 2007 Author Share Posted January 7, 2007 yea wiring ok ,tested harness as per gtr workshop manual,never herd of the hydraulic unit needing replacing ,but u never know,was hoping someone had an easy fix to the problem Link to comment https://www.sau.com.au/forums/topic/150257-4wd-light-error-r32-gtr/#findComment-2800719 Share on other sites More sharing options...
neergnevets Posted March 28, 2007 Share Posted March 28, 2007 any further advice, have same problem. Link to comment https://www.sau.com.au/forums/topic/150257-4wd-light-error-r32-gtr/#findComment-3013295 Share on other sites More sharing options...
Phrase Posted March 29, 2007 Share Posted March 29, 2007 sorry guys, I havent had that one yet.....i'm working through 19 flashes which is the ETS circuit (i think). good luck. Link to comment https://www.sau.com.au/forums/topic/150257-4wd-light-error-r32-gtr/#findComment-3014826 Share on other sites More sharing options...
gurglr Posted March 29, 2007 Share Posted March 29, 2007 Its no help to you but I've just fixed a 16 flash problem. 16 flashes means lateral g-sensor. $1800 new from Nissan, $150 from SSS. Put it in, wasn't expecting it to be be fixed, but it was. The more problems I solve with my car the more respect I have for our fantastic 1989 (although mine is a '93) car with great diagnostics and through workshop manual. Trust the diagnostics and manual. Link to comment https://www.sau.com.au/forums/topic/150257-4wd-light-error-r32-gtr/#findComment-3016666 Share on other sites More sharing options...
GTS4-32 Posted March 29, 2007 Share Posted March 29, 2007 while wer at it, anyone got a solution to 22 flashes (oil level sensor and circuit) Link to comment https://www.sau.com.au/forums/topic/150257-4wd-light-error-r32-gtr/#findComment-3016865 Share on other sites More sharing options...
Topaz Posted April 3, 2007 Share Posted April 3, 2007 When do these flashes occur for diags? is it just the acc on or engine on? Does the 4WD light flash 'x' amount of times and then start again after a small pause or something? Mine isn't flashing, it would just be good to know. And where do you get the fault codes? Link to comment https://www.sau.com.au/forums/topic/150257-4wd-light-error-r32-gtr/#findComment-3026171 Share on other sites More sharing options...
Phrase Posted April 3, 2007 Share Posted April 3, 2007 topaz, the ATTESSA controller in the boot has an LED that flashes. Shove your noggin in the boot and have a look..... The dash light doesnt flash. Good luck Link to comment https://www.sau.com.au/forums/topic/150257-4wd-light-error-r32-gtr/#findComment-3026856 Share on other sites More sharing options...
Topaz Posted April 4, 2007 Share Posted April 4, 2007 I will report back *salute *stamp *turn *depart Link to comment https://www.sau.com.au/forums/topic/150257-4wd-light-error-r32-gtr/#findComment-3028136 Share on other sites More sharing options...
nanuGTR Posted April 25, 2007 Share Posted April 25, 2007 yea i have the same problem 18 flashes with 4wd light in the trunk.... i think we need to replace the 4wd pump and that should fix it.. Link to comment https://www.sau.com.au/forums/topic/150257-4wd-light-error-r32-gtr/#findComment-3073761 Share on other sites More sharing options...
Guest mbarm8791 Posted May 1, 2007 Share Posted May 1, 2007 hey does any one have 33 GTR v-sepc codes for ATTESA im getting 77 and dont know what it is cheers Link to comment https://www.sau.com.au/forums/topic/150257-4wd-light-error-r32-gtr/#findComment-3088673 Share on other sites More sharing options...
SkyKC Posted January 29, 2008 Share Posted January 29, 2008 I have r33 gts4 1. i cannot find this ecu thingy in my car to find the error code (My 4wd and abs is on all the time), does workshops have these little computer thing which you can plug to your car to see what errors they have? Link to comment https://www.sau.com.au/forums/topic/150257-4wd-light-error-r32-gtr/#findComment-3610836 Share on other sites More sharing options...
GTR747 Posted January 29, 2008 Share Posted January 29, 2008 while wer at it, anyone got a solution to 22 flashes (oil level sensor and circuit) Check your clutch/brake fluid level under the bonnet and your power steering level aswell - check your attesa system oil level aswell. that should fix it, if not, you need a new switch (oil sensor) Everyone else, i found these links on a UK GTR forum... http://tyndago.googlepages.com/gt-rattesainfrormation http://www.gtr.co.uk/forum/upload/87007-4w...light=4WD+Light just to name a few !!!! There is heaps of info on this site if you do a search. Hope this helps Link to comment https://www.sau.com.au/forums/topic/150257-4wd-light-error-r32-gtr/#findComment-3611068 Share on other sites More sharing options...
robbieraver Posted January 30, 2008 Share Posted January 30, 2008 i have fixed a few gtr's with this problem, 18 flashes pressure switch, 9 timesout of 10 the pump will have to be removed and replaced. sorry. Link to comment https://www.sau.com.au/forums/topic/150257-4wd-light-error-r32-gtr/#findComment-3612857 Share on other sites More sharing options...
CeJay Posted September 18, 2008 Share Posted September 18, 2008 anyone got a price on the ets pressure switch as I think mine is fuba as well as I'm getting a number 13 error. Is it a buy off the wreckers jobbie or new? Link to comment https://www.sau.com.au/forums/topic/150257-4wd-light-error-r32-gtr/#findComment-4141246 Share on other sites More sharing options...
norto333 Posted December 11, 2013 Share Posted December 11, 2013 i have fixed a few gtr's with this problem, 18 flashes pressure switch, 9 timesout of 10 the pump will have to be removed and replaced. sorry. what do the pumps cost thanks ray Link to comment https://www.sau.com.au/forums/topic/150257-4wd-light-error-r32-gtr/#findComment-7140965 Share on other sites More sharing options...
