Hi guys, I've been reading around the forums & used the search function a couple of times but there are still a few things I can't seem to find.
I'm fairly new to turbo modifications, having recently upgraded from a n/a R33 & I was just wondering if I'm heading in the right direction with my modification plans. I am a firm believer in doing things right the 1st time around.
My car is a daily driver, so I'm not chasing a huge power figure, just improving the performance of my car without sacrificing drivability as I'm getting bored of the stock power & I would like to start taking it out on the occasional track day :P
* I already have:
- Turbosmart dual stage manual boost controller recieved as a x-mas pressie (not installed yet)
- Apexi Power FC for the r34 gtt (not installed yet)
- HKS mushroom pod filter with factory snorkel & custom intake box (on the car when I bought it)
- Plumb back BOV (on the car when I bought it)
* I am planning:
- 3" stainless exhaust with split dump pipe
- FMIC
- Fuel pump
- Coilover suspension (later on)
I'll be keeping the stock turbo, what would be the highest psi I could run before pushing the limits of the stock R34 turbo?
I'd really appreciate any suggestions if there are any aspects of mods I might have overlooked.
also any suggestions on what you use & recommend
https://www.sau.com.au/forums/topic/150286-modifications-list/
Couple of good threads
http://www.skylinesaustralia.com/forums/in...showtopic=45218
http://www.skylinesaustralia.com/forums/in...howtopic=104405
Have a read of the Forced Induction sticky thread :(
More stuff in there to help ya out also
Awesome guys! Thanks for the helpful responses. :O
Skyline couple: It's definitely not a stock airbox that I have as I know what it looks like. It's got the factory snorkel, but the box is made of sheet metal or aluminium with some foamy stuff on the inside to shield the pod. Was on the car when I bought it.
Cheers everyone
>_<
    • As I implied in my post, I have NO idea what the were. But in case I didn't make it clear, the way they performed was brilliant; whatever the brand was. I think it was the compound that made the difference. And if they were Bendix, then sign me up, I want another set. I did drive down mount Ousley (just outside of the Gong) a few times, and they showed no untowards performance.   Its not the low dust that I am looking for NOW. At the time I needed low dust, but now I have no issues with dust but want the initial/early bite of the pads that were used. Yeah, the early cold squeal may of been due to a missing shim or such.  And to repeat, its not the low dust I am seeking, its the initial bite of the pads and increase in bite as  the warmed up during each breaking. As soon as I let off, I don't remember the breaks being extra sticky if I used them again soon after. But I also did not test that theory.   Thanks for the recommendation, But I would prefer to choose something specifically with the behaviour I described.   I assume that they didn't use the default compound off the shelf, as we discussed the dust issue at length. And the early squeal when cold, I have seen the sound is more of an issue with some pad compounds. Mostly ceramic, which also are said to produce less dust.
    • Well, in 2007 he must have been charging about $1800 an hour. He only looked at the car for 5 minutes. And another 4 to write the report wrong, and another minute to correct it. Mind you, this was for a car that was: Stock engine, fmic (hole in drivers guard), all alloy intake and custom air box, 3 inch turbo back exhaust, lowered, and a set of 17" Advans (255/40/17 rear and 235/45/17 front). It was nothing crazy. The blue slipper wanted the "hole in the guard" engineered. But that was because he got the shits that I wouldn't "relocate the battery from the boot, back to the factory position in the engine bay"... In an R33 GTST...     Also for emissions, E85, and don't go wild on timing. It's amazing how the closer you get ignition timing towards max torque, the last couple of degrees really throw NOx counts right up. And for the huge increase in emissions, it's only a small increase in torque.
    • He'll be looking down and swearing about "the damn apprentice" for trying to convince Duncan to use percussive maintenance... 😛
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
