getting a few bolt ons for my GTR soon and i've purchased most of the parts.
Here they are
34 N1 turbs
trust dumps/fronts
PFC
cat
exhaust
JB clutch
bosch 040
sard 700 inj
THe last thing i don't have is a boost controller.
I haven't decieded between the turbotech one ($22) or a EBC.
Can someone explain the pro and cons of both and if the EBC is a better way to go, should i go for the apexi one or somthing else.
Thanks.
https://www.sau.com.au/forums/topic/150293-ebc-or-turbotech-bc/
i've heard alot of good feedback about the turbotech boost vavles, like they come onto boost quicker and there very accurate. but i used to always get told that you should only use EBC's because they dont spike and you can see wat you've set your psi to wihout haveing to drive it and read ur psi off you boost gauge.
id rather the EBC but the cost of them compared to the turbo tech units is a bit much (im still an apprentice) so id get the turbotech boost valve.
dont know if that helps at all . . .
Anything up to 15 - 18 psi the turbotech will do the job just fine... i have been running it in my car on 10psi for quite sometime without a single spike... but my car is pretty much stock...
For larger power applications and high boost settings, a decent EBC is the way to go... the Greddy Profec II are selling for $390 delivered! Pretty cheap investment for an accurate boost control unit with incabin adjustment and setting...
Cheers
The other option is to get a larger spring for the turbotech, which will hold high boost better.
I've seen both on a dyno, and the EBC is obviously better, but the turbotech does a very good job. EBC sat right on the set boost, the turbotech creeped 2psi over 4000rpm, no spiking though and good boost build. Hard to compare that to EBC though cos they were on different cars with different turbos
I've got the Blitz DSBC spec-R and yeah, very happy with it.
Edited by salad
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • I was told that they no longer fit high flow cats over here for some weird reason. But one exhaust shop said that they may have some old stock which they could fit if I wanted. However, I have other issues to handle at the moment and this is not a priority for now.
    • Yeah, you are right. It seems easier and more reasonable to boost the engine. And as you said the blocks are very similar but the cylinder bores are different.
    • Sound logic, but in actuality way more illegal than just having the wrong pipe. Normally, doing something like that would be forgery. Meaning you may have certain documentation for vehicle parts, but the actual parts are different ones and you just assign them the numbers and badging from the documents. But nevermind that. Nonetheless, I AM curious if this pipe was ever made by any official manufacturer this way, because I honestly am not familiar with this pipe layout and shape. As I will be putting on the HKS Silent Hi Power once my exhaust gaskets arrive, as long as it sounds right I will just roll with this front pipe. I can always order the actual Mines part if I run into legal issues. It would be an unnecessary expense as there is lots of other problems I have on this car as of now.
