getting a few bolt ons for my GTR soon and i've purchased most of the parts.
Here they are
34 N1 turbs
trust dumps/fronts
PFC
cat
exhaust
JB clutch
bosch 040
sard 700 inj
THe last thing i don't have is a boost controller.
I haven't decieded between the turbotech one ($22) or a EBC.
Can someone explain the pro and cons of both and if the EBC is a better way to go, should i go for the apexi one or somthing else.
Thanks.
https://www.sau.com.au/forums/topic/150293-ebc-or-turbotech-bc/
i've heard alot of good feedback about the turbotech boost vavles, like they come onto boost quicker and there very accurate. but i used to always get told that you should only use EBC's because they dont spike and you can see wat you've set your psi to wihout haveing to drive it and read ur psi off you boost gauge.
id rather the EBC but the cost of them compared to the turbo tech units is a bit much (im still an apprentice) so id get the turbotech boost valve.
dont know if that helps at all . . .
Anything up to 15 - 18 psi the turbotech will do the job just fine... i have been running it in my car on 10psi for quite sometime without a single spike... but my car is pretty much stock...
For larger power applications and high boost settings, a decent EBC is the way to go... the Greddy Profec II are selling for $390 delivered! Pretty cheap investment for an accurate boost control unit with incabin adjustment and setting...
Cheers
The other option is to get a larger spring for the turbotech, which will hold high boost better.
I've seen both on a dyno, and the EBC is obviously better, but the turbotech does a very good job. EBC sat right on the set boost, the turbotech creeped 2psi over 4000rpm, no spiking though and good boost build. Hard to compare that to EBC though cos they were on different cars with different turbos
I've got the Blitz DSBC spec-R and yeah, very happy with it.
Edited by salad
    • I haven’t taken them out of the cases yet    inside the box is this packaging which is pretty much like a massive blister pack
    • Purchased a NC MX5 a while ago Basic suspension mods done, BC coils and Whiteline sway bars  New DBA calipers, discs and pads Added some 17 x 8 Konig Decagrams with 215/45 17 PS5's Added some typical NA bolt on's, i.e. full exhaust and intake  Added 0.5ltrs with a MZR2.5 swap, nice bump in torques  Found a detachable hard top which is locked in for a colour match with my local paint shop in Feb 25, this also includes some PDR as it has received a few love taps from parking in the local shops when in the hands of my Minister for War and Finances, me, I park nowhere near other cars and typically park on the street The little thing is awesome, I drive it everywhere, it handles like a dream whether I'm up it or just cruising  But now,  because I'm a idiot, I keep looking at turbo kits....... did I mention I'm a idiot Why is dose so appealing  All of the NA 2.5 glory, well.......until sometime in 2025 anyway....🤪
    • I would not be surprised if you are the only person on earth that has the interest/desire to do that lol.  The Haltech base map is a really good starting point, the car will fire easily and drive very well, even on mild boost levels. To me, following your advice sounds like some sort of ancient Chinese water torcher lol (this is not an insult Josh, never change <3)
    • Those car show concepts from the 2000's and 2010's like the Floria and IDx were brilliant and should've gone ahead, at least one of them. But neither Honda nor Nissan are thinking about affordable performance any more, which is truly sad.  Even if Toyota's liquid hydrogen ICE development reaches the point where it's commercially viable and the infrastructure to support it, Honda/Nissan would have to wait until Toyota allow fee access to their patents to offer it with any smaller performance models they released to take advantage of it.
    • A sporty manual RWD coupe with a IL4 Honda engine would only be a good thing I assume we won't see anything released for a few years though, unless informal talks and designs have been going on for a few years,  and due to the current, and future, emmisions and safety requirements, I assume anything "sporty" they would do would be at least some hybrid thingie And hopefully anything they are thinking of has nice lines, without lots of plastic and fake bits hanging off it like that horrendous FK8 that looked like it was designed by a 13 year old The other issue of course in the current market is cost, currently the type R is around $70k, a twin is around $50k Meh, I'm old and grumpy and would rather buy a older model car and waste my coin on that than buying anything currently available new
