not saying you don't get advantages but there are much easier and cheaper ways to go about getting that extra response.
once those things have been done for sure look into it.
sorry to say lads but machineing and shimming buckets taking alot longer than they thought due to the increased lift. they a bit worried about bending valve shafts with the increased duration combined with vvt.
after a big weekend head will be back to me on monday, fingers crossed.
for anyone in the know what is a resonable price for a cam belt and a new set of bearings.
since the motor is apart anyway it makes sense to hit it all now.
obviously when you start running that sort of compression things wear alot faster if you don't do it right. thats why i've spent so much time on the head to get it right which left no money to balence the bottom end. with that in mind red line will probably be about 7500. if i can find a descent harmonic balancer i might stretch it out to 8000.
everything that i've done to date have been at a tune length. paid through the ass for tune length custom extractors. cams that have power band that line up with that and a port job that reflects that as well.
basically that means that it won't be the highest total hp i could have gotten but it will be the hardest accelerating and constatly be in power band when you drive it right.
I haven't seen an rb25 built to this extent and this quality so im interested to see what sort of power i get. i know that some of the boys here have ported rb30de's but lifting and machining buckets angel cutting all round and high compression to my knowledge hasn't been done.
if someone has seen this and can give me an idea of power to expect pleae let me no.
Sounds awesome mate cant wait for the results.
Performance Wholesales at slacks creek here in brissy sell speced up balancers for GTR's... pretty sure that it would be compatible, probably worth a look into.
yeah do you know what sort of price there talking?
not sure if it will be worth it at this stage. for longevity of the motor it probably is but outright speed i don't know it would be that benificial?
just got short shifter in and fitted it feels pretty nice. keen to see how she runs.
flywheel is now machined up and ready to go in. total weight 4.2kg. bit worried bout how she'll be driving around on the street but im sure once i learn how it feels it will be fine.
just checked up on head and its looking good for monday which means head goes on 20th tuned on the 23rd.
the exit runners on the head how important are they once you have a good set of pipes?
im tempted to tell the guy grind them out but not sure if its going to kill flow rather than help it.
has anyone here removed them and what sort of results did you see?
hell no thats just crazy. after market style all the way. started at 4.8kg just took bits and pieces out and balenced it with new clutch.
all the added power with such light weight fly clutch combo the short tail shaft of the sil big lsd and big tyres i can see my gearbox going boom if im not to careful.
sorry to disapoint boys but will be a few more days before engine is back together having trouble sourcing good quality idler bearing.
exit runners still causing concern with the flowbench readings.
looking to be back together and on the road by wed next week.
i looked into because it looked pretty good but the only real gains you get are in your air intake because they just can't do it anywhere else. ie your inlet manifold. so you still have to get a good porting job anyway. when i sent my head down i paid to get the inlet cleaned up anyway so any gains that extrusion honing would have gotten me i'll get, and then some.
i also wanted my inlet split to get more flow again which again you need to get done at a good porting shop.
if anyone has any more ideas like this please let me no. still keen to pick up any extra power i can and still a few days left to do so.
twin throttle bodys? its been done on a couple of the rb30des on here. im just starting on it now.
or have you got somthing else planned? i cant quite rember now.
if you really wanted to try somthing totaly differnt. what about increasing the size of the intake runners? im not sure if that would be a gain or a loss. but its somthing i havnt heard about...
also what about a thin copper head gasket? to increas compression even more
oh and mb to avoid alot of blow by some oil restrictors? or mb thats just what you need for rb30s... i know i need some...
Contact your local CBC Bearings, they do a kit which replaces your seals/idler/tensioner/belt at a great price, plus all the stuff they use is genuine... just not in 'nissan' boxes
I know, because I'm a Rep for them :/
Kit will set you back around the $250 mark (with racing belt)
damn monster your like a few days to late. grabbed a new racing belt the other day and idler bearing is on the way but thanks i'll keep that in mind, im sure i'll be building again in the not to distant future.
as for twin throttle bodies no have no plans as such, yet. seeing how this package goes then moving onto a twin throttle setup if i feel the need.
the inlet runners beind made larger was on the books but this will only be done if it shows up on the flow bench that we'll see gains. it still being played with and little things being changed and the gains are really starting to pile up.
as for the copper head gasket we've worked out all the comprension ratings to give her as much as she can handle with just a normal head gasket. bearing in mind that if an rb30 bottom end was to go on the compresion would increase again.
whats mb? :)
    • Last year I got a set of MCA street coilovers for my turbo Forester after my son hitting a concrete gutter/wall on a small bridge causing the whole drivers side suspension to get bent because the rain just made the car slide out I love them, I think they were $2400. even had a hiccup of have the wrong hub configuration (my fault) so got onto MCA and they sent the correct shock ends overnight parts from QLD, for free!  I was very impressed with their customer service and quality of the product
    • They've had some weird failures on their brake actuators. One of them was because they added some kind of lubricant to the factory fill brake fluid that aftermarket brake fluid didn't have so it would affect the seals. Another was just mysterious, probably internal corrosion or something eating away at Prius brake actuators. Parts alone for those are a few thousand USD so not a cheap fix.
    • Selling a genuine Nissan Skyline R33 Coupe 8-Pin Power Window Master Switch Part No. 25401-26U10 Price $300   IMPUL Gear Knob – Rare JDM Upgrade Upgrade your interior with this genuine IMPUL gear knob – a rare and stylish addition to any JDM build. Premium quality, perfect fit, and an authentic Japanese touch for your ride.  Price:$300 Nissan Skyline R33 (Series 2) Sedan Tail Lights Immaculate Condition OEM JDM S2 a pair of OEM Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state. Price:$900   Located in Melbourne (Western Suburbs) – Shipping available Australia wide at buyer’s expense. DM if you need anymore details.
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
