Ey,
i got a mate that suggested i put bigger injectors in my rb20. At the moment i got std injectors, with highflowed r33 turbo, front mount, fuel reg, fuel exhaust system, pod filter. Im planning to replace the std ecu with microtech in the next 3-4weeks. IS it a big difference with bigger injectors? if so....in wat way? and if 800cc are too big...hopw big should i go?
https://www.sau.com.au/forums/topic/150329-sard-800cc-twin-jets/
Im in the same boat but with an RB25DET.. I'm getting a highflow turbo, FMIC, Walbro pump and Haltech ECU fitted soon and was wondering wether to put a fuel pressure reg or get larger injectors.... $250 Vs $900 :( few tuners said the highflow turbo would max at 240 - 250 rw/kw which the stock injectors with rising rate FPR have achieved on some R33's at 90% duty...
Cheers
With larger injectors and larger fuel pump, the standard fuel rail pressure will be fine... theres no need for an after market FPR. You only need a rising rate FPR when the injectors are closing to their max duty... 800cc's are good enough for approx 800hp... 550cc will be a better option cause they will be easier to tune...
Edited by QRI05E
Probably GTR injectors + FPR would be your best bet... 480cc and i "think" they are direct drop in cause both the RB20 and RB26 are both top feed if im not mistaken?
Otherwise Nismo 550cc will more then enough and you wont need a rising rate FPR
Cheers
Edited by QRI05E
Well once you tune the ECU, any size injectors can be used for example at 250rw/kw the Nismo 550cc might reach a duty cycle of 65% where the Nismo 800cc wil only reach 50%. But this also means the larger the injector the harder it is to tune therefore you should only ever get injectors to match your power goal...
250rw/kw = 550cc max otherwise would be overkill
GTR injectors are 480cc so theoretically will support 480hp (80% duty) at the fly wheel. Therefore 480hp - 30% (drive train loss) = 336rw/hp = 250.56rw/kw (80% duty)
Hope this helps
Regards,
Sarkis
For a max power of 250rw/kw, Yes 800cc are an overkill... Dont get me wrong, they will still work fine but wont be utilized as well as the 550cc in other words you wont be using them to their intended potential...
Cheers
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
