K so just for my own knowledge can some one give me the turbo sizes on the following
Stock rb20det turbo (t25?)
Stock rb25det turbo (t28?)
Stock rb25det neo/r34 turbo (would it be like a t28/30 because of the larger rear housing?)
Thanks, i did try searching but all i found was the rb20det size and i already knew that
https://www.sau.com.au/forums/topic/150347-turbo-sizes-on-stock-skylines/
stock rb20 = t3/t25 (smallest)
stock rb25 = t3/t25 (medium)
stock rb25 neo = vg30 size (large)
stock rb30et = t3/t25 (not sure, large i think)
smallest = somewhere near 0.45a/r maybe?
medium = 0/50 a/r ish ?
large = 0.55 a/r ish ?
t28 is found on the sr20 (silvia, gtir, 200sx, 180sx)
none whatsoever i dont think, the t25 i am pretty sure referes the flange option, which is the connecting plate to the manifold.
ie: an rb30et with a t25 flange should plonk on the stock skyline t25 manifold with no problems (dumps, exhaust aside etc)
A/R
A/R describes a geometric characteristic of all compressor and turbine housings. It is defined as the inlet cross-sectional area divided by the radius from the turbo centerline to the centroid of that area.
* Compressor A/R - Compressor performance is largely insensitive to changes in A/R, but generally larger A/R housings are used to optimize the performance for low boost applications, and smaller housings are used for high boost applications. Usually there are not A/R options available for compressor housings.
* Turbine A/R - Turbine performance is greatly affected by changing the A/R of the housing. Turbine A/R is used to adjust the flow capacity of the turbine. Using a smaller A/R will increase the exhaust gas velocity into the turbine wheel, causing the wheel to spin faster at lower engine RPMs giving a quicker boost rise. This will also tend to increase exhaust backpressure and reduce the max power at high RPM. Conversely, using a larger A/R will lower exhaust gas velocity, and delay boost rise, but the lower backpressure will give better high RPM power. When deciding between A/R options, be realistic with the intended vehicle use and use the A/R to bias the performance toward the desired powerband.
The std turbos on 90's era RWD Skylines were a Nissan/Hitachi ceramic turbined ball bearing series . They have a "T3" style mounting flange and from memory the compressor backplate diametre is almost the same as Garrett T3 . I think the water coolant banjo bolt thread is the same size as Garret water cooled T3/small shaft T4 cores .
Basically they used small/med/large sized exhaust housings for 2 , 2.5 , 3L sized engines and their respective exhaust gas flow requirements . The turbines were all the same size . Note some R34 RB25DET's used the larger 3L exhaust housing . The compressor housing as you would expect is smallest on RB20 DET's , the largest was RB25DET and the VG30 just a tad smaller than RB25's . You can easily tell the RB25 and VG30 types because they have "Nissan" cast into them in bold block lettering . The RB20 is a more crude style casting and the aluminium more of a silver than a grey colour . The size of the three bolt comp housing outlet is smaller on the RB20 turbo than 25 or VG 30 type . The VG30 type has a straight barb type adapter fitted here whilst the RB25 ones have a 90 degree elbow fitted to theirs . I can't remember what the RB20 type had .
Some people have found a Garrett type comp housing on one variation of the R34 GTT but have not seen this type myself .
Commode VLT's use a small turbine series version of Garretts watercooled T3 bush bearing turbo with Nissan compressor and turbine housings . These have the same T3 mounting flange .
T28 is different again with smaller shaft and bearings/cartridge , is available in bush or ball bearing though the BB types generally have "GT" series compressor and turbine wheels . T25 was a slightly smaller wheel housing variation of the T28 theme . T2/T25/T28 are of the same family core wise and generally use the T2/25/28 mounting flange though there are some T3 flanged turbine (exhaust) housings out there ie from HKS .
The GT25 BB centre section is virtually the same shaft and bearing wise from GT2554R right throught to GT3582R , this last one is slightly larger on the compressor end of the turbine shaft . These can have T2/25/28 flange or T3 depending on who made the turbine housing to suite which application . ATP even now do a T4 flanged housing for the GT3582R .
Lots of variations , cheers A .
Edited by discopotato03
Not quite correct there. CA silvias use T25's and SR silvia's use T25g turbos. T28 turbos didnt come in till the S14. Gtir did however get a T28 with a larger rear housing that was the biggest untill the S15 T28 came out.
Cheers
Chris
There is a huge range of Garrett factory T2/25/28 turbos and many of their own hybrids . They were developed because Garrett felt that the ageing T3 had more rotating group innertia than they wanted and the unit was a little bulky for small engine applications . The writing is on the wall when you have .36 A/R exhaust housings to get a turbo going .
They gained a little with the smaller diametre turbine shaft and bush bearings which have less oil shear drag . Innitially they were a bitch of a thing because Garret refused to sell rebuild kits for them and you could only buy cartridges , sound like the BB scenerio ?
Too lazy to look it up but the Pulsar GTiR's T28 was an odd ball specific to that engine/car . Its turbine was 79T from memory and the turbine housing .86A/R . I have a feeling that the compressor is T3 series and its housing a face lifted TO4B . The rally peoply didn't really like them because they were too laggy - amongst many of that cars other insurmountable weight distribution/cooling/body flexing etc problems . It was very likely the beginnings of what became the DP GT2860RS turbocharger .
