Hi all,
I'm wrecking a R33 GTS T sedan, series I Oct 1994 gunmetal grey in colour. The damage is around the B pillar and roof on the passenger side, so the front passenger door is no good, and there is a slight buckle in the roof just above the B pillar on the passenger side. I have already bought another GTST which is an auto, so all the parts I need to do the manual conversion is not for sale eg, gearbox, diff centre, tailshaft, centre console, clutch and pedals.
Otherwise everything else is for sale. For all small items please PM me for availability and prices.
I'm on the central coast in NSW and travel to Sydney regularly, so I can bring parts to Sydney for inspection if required.
RB25DET engine complete with loom and ECU (Between 80 and 90k)( I have a manual and auto ECU) you choose which ECU. $1950.00 (AFM, radaitor, aircon compressor, power steering pump and alternator separate).
RB25DET engine 225K, broken ringland in cylinder 1. All other cylinders have good compression. Will separate all parts. Motor was still running when removed. Was only removed due to lack of compression in cylinder 1
Full rear cradle with diff from GTST auto $750 (not available until Feb 2007)
ABS system to suit R33 complete with all harnesses and all brake lines $300.00
I have a whole car to wreck so please PM me with anything U need and I'll give U a price and send some pics
As I get through different stages of wrecking the car, I'll take photos amd post them to see if anyone is interested in anythng
Update 27/1/07
Dash/console/glovebox removed. All items for sale. Please let me know if you're interested and I'll send pics of individual items.
Photo's of behind the Dash Area. Anyone interested in anything in these photo's ?? All wiring looms are fully intact.
View from Drivers Door
View from Passengers door
Edited by blukie
https://www.sau.com.au/forums/topic/150361-gts-t-r33-sedan-wrecking/
Hay champ.. Could you please send me some pics of the aircon hose.. The one from the firewall to the compressor..
As long as that hose doesnt have a hole or anything in it.. i could be keen.. Should be the one with heatwrap around it??
But please do send me some pics
Cheers
Edited by siddr20
siddr20 - I just had to find a new one of those pipes (side suction pipe i believe its called), they have different size nuts on the part that connects to the firewall thread from model to model. Make sure you got the right size one, as I bought one off a 97 model s2 r33 and it didnt fit my 96 series 2 r33!! shithouse.
Cheers
Howdy, I'm sorry this hose is cut.
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
