MistR33td Posted January 7, 2007 Share Posted January 7, 2007 yesterday arvo i was driving down gorge road, put it in 3rd and gunned it basically and it hit 5000 rpm in 3rd and sounded like it was bottoming out...happened for like 2 mins coz i kept trying to see wot happens in high revs. Everything seems to b alrite now but i dont kno...hope its nothin. can sum1 help me with this. cheers Link to comment https://www.sau.com.au/forums/topic/150367-r33-revs/ Share on other sites More sharing options...
4door_Sleeper Posted January 7, 2007 Share Posted January 7, 2007 sounded like it was bottoming out...happened for like 2 mins coz i kept trying to see wot happens in high revs. Do you mean t sounded like it was scraping on the ground? "bottoming out" or was it an engine noise, perhaps a boost cut? Link to comment https://www.sau.com.au/forums/topic/150367-r33-revs/#findComment-2800912 Share on other sites More sharing options...
MistR33td Posted January 7, 2007 Author Share Posted January 7, 2007 i mean like boost cut...but it almost felt like the car was pulling back.......weird shit. any idea wot it cld be? Link to comment https://www.sau.com.au/forums/topic/150367-r33-revs/#findComment-2800921 Share on other sites More sharing options...
Bl4cK32 Posted January 7, 2007 Share Posted January 7, 2007 dyno time. Link to comment https://www.sau.com.au/forums/topic/150367-r33-revs/#findComment-2800957 Share on other sites More sharing options...
MistR33td Posted January 7, 2007 Author Share Posted January 7, 2007 dyno time. nah but it doesnt do it anymore, i dono i just wana kno if it cld of been an air bubble or sumthin i have no idea. justwanted to kno if i shld worry about it Link to comment https://www.sau.com.au/forums/topic/150367-r33-revs/#findComment-2801033 Share on other sites More sharing options...
PRO AERO Posted January 7, 2007 Share Posted January 7, 2007 I HAD SAME PROBLEM 2DAY....DROVE CAR 3 HRS LATER AND WAS FINE...IT WAS HESITATING UNDER BOOST WAS YOURS? Link to comment https://www.sau.com.au/forums/topic/150367-r33-revs/#findComment-2801060 Share on other sites More sharing options...
MistR33td Posted January 7, 2007 Author Share Posted January 7, 2007 I HAD SAME PROBLEM 2DAY....DROVE CAR 3 HRS LATER AND WAS FINE...IT WAS HESITATING UNDER BOOST WAS YOURS? yeh it felt like the car wldnt go over 5000 revs, almost like it was pulling back..but 10 mins or so later it seemed fine....no idea wot was goin on. Link to comment https://www.sau.com.au/forums/topic/150367-r33-revs/#findComment-2801063 Share on other sites More sharing options...
Ronin Posted January 7, 2007 Share Posted January 7, 2007 could be ignition module on the way out Link to comment https://www.sau.com.au/forums/topic/150367-r33-revs/#findComment-2801311 Share on other sites More sharing options...
sinistaGTR Posted January 7, 2007 Share Posted January 7, 2007 maybe spark plugs aswell Link to comment https://www.sau.com.au/forums/topic/150367-r33-revs/#findComment-2801375 Share on other sites More sharing options...
Nightcrawler Posted January 7, 2007 Share Posted January 7, 2007 It could have been detonating when it is hot. My other tip would be coil packs on their way out and got hot. My S15 did this for a while and it turned out to be dirty spark plugs. Mechanic was sure it was coil packs but turned out it wasn't. I would strongly suggest chucking it on a dyno to find out what is going on asap as you could blow it up quick smart if you don't. Link to comment https://www.sau.com.au/forums/topic/150367-r33-revs/#findComment-2801597 Share on other sites More sharing options...
savage GTR Posted January 7, 2007 Share Posted January 7, 2007 could also be airflow meter. could be worth getting some cleaner for it. Link to comment https://www.sau.com.au/forums/topic/150367-r33-revs/#findComment-2801831 Share on other sites More sharing options...
J_Red33 Posted January 7, 2007 Share Posted January 7, 2007 (edited) I have trouble in the colder weather with overboosting on the standard solenoid boost control once over 5000 rpm, when it boosts too high it's does the rich & retard trick & it backfires due to overfueling too. I the hot stuff when it's warmer it's ok. I didn't have an issue until my exhaust system was fitted. Going to be getting an EBC soon Edited January 7, 2007 by JazzaR33 Link to comment https://www.sau.com.au/forums/topic/150367-r33-revs/#findComment-2801839 Share on other sites More sharing options...
savage GTR Posted January 7, 2007 Share Posted January 7, 2007 Jazza , more than likely caused by change in back pressure from the new exhaust. Link to comment https://www.sau.com.au/forums/topic/150367-r33-revs/#findComment-2801860 Share on other sites More sharing options...
Deluxe Posted January 8, 2007 Share Posted January 8, 2007 It could have been detonating when it is hot. Yeh true that Andrew, mine was doing the same a little while ago, It's like your hitting limits early and flames were coming out the back! I needed a tune, got one and BANG all was good! Id suggest a tune for sure! Link to comment https://www.sau.com.au/forums/topic/150367-r33-revs/#findComment-2803719 Share on other sites More sharing options...
Madaz Posted January 8, 2007 Share Posted January 8, 2007 i agree i belive its detonation stop driving fast when that happens it happens to me when the turbo is hot also or if i run too high a boost Link to comment https://www.sau.com.au/forums/topic/150367-r33-revs/#findComment-2804024 Share on other sites More sharing options...
MistR33td Posted January 10, 2007 Author Share Posted January 10, 2007 i spoke to to one of my mates and he reckons coz my pod and catback with my original ecu, nothing has been updated there can sumtimes be a slip in the fuel and air ratio or sumshit.....u reckon this is tru? by the way car has been fine since hope it stays away, lol Link to comment https://www.sau.com.au/forums/topic/150367-r33-revs/#findComment-2809820 Share on other sites More sharing options...
Pauly33GTS-t Posted January 10, 2007 Share Posted January 10, 2007 (edited) i had the same issues mate, i bought my car stock with 3 inch cat back and K&N filter, i had misfiring or detonation (more likely det) at higher rev range with the turbo being boosted to 9psi. it was fine at 7 but hated 9. So I changed all the spark plugs and that helped alot, also. I heard that you need to gap your spark plugs to .6 or something like that to increase the spark for higher boost. im going to try that next along with a splitfire coil pack system from the group buys here next week. mind u today I have got my 3 inch dump pipe, hi flow cat and screamer pipe fitted, that might increase my back firing ill have to see when it happens, it back fires randomly at the moment after around 10 mins of drivin around when the exhaust gets hotter. Edited January 10, 2007 by Pauly33GTS-t Link to comment https://www.sau.com.au/forums/topic/150367-r33-revs/#findComment-2809861 Share on other sites More sharing options...
MistR33td Posted January 10, 2007 Author Share Posted January 10, 2007 ight cheers for that man, wen i get my car serviced or wateva soon i'll get em to sort it out, lol. thanks Link to comment https://www.sau.com.au/forums/topic/150367-r33-revs/#findComment-2809876 Share on other sites More sharing options...
Madaz Posted January 10, 2007 Share Posted January 10, 2007 how much were your coil packs on group buy Link to comment https://www.sau.com.au/forums/topic/150367-r33-revs/#findComment-2810777 Share on other sites More sharing options...
