Yeah, so I'm topic flooding today hehe
Anyways i'm trying to decide what to do next to my car performance wise
Currently i have a R34Neo turbo on my car, and it is fairly laggy and no very powerful. So i was wondering if i get it hi-flowed whether it will be even laggier, because any laggier and it would be useless off the strip in which case i'd get a 33 hi flowed or a 2530. I am also wondering how a 2530 compares to a hi flowed 33 or 34 neo turbo power wise? I know the prices are similar, although the 2530 are hard to find. Which should i go with? I was thinking of doing a rb25de transfer into this car but theres to many problems and i wanted it to be relatively original (+ the engine sounds so sweet)
Also im currently only making 163 rwkw (althought that was done before split dump and 3" Cat, i don't think these would make much difference) with these mods so with a hi flow or the 2530 i would expect to make about 190 rwkw, so my current AFM should be alright correct?
Dyno (dunno if it's helpful, maybe someone can see some problems)
https://www.sau.com.au/forums/topic/150396-2530-hi-flo-r33-or-hi-flo-r34-neo/
Well... a hi-flow is larger wheels... so its going to be laggier.
If you class an R34 turbo as not so good on an RB20, then your really in no-mans land mate as it doesnt get any better in terms of response.
Its an RB20, so you need to wait for it to really come on.
R33/R34 hi-flows are virtually the same thing, 5-10rwkw difference really
Ah really, damn, just the thing doesn't start boosting till about 4k rpm and take off in first is horrible, i was assuming 2530 would be about the same lagginess because alot of people complain about laginess in the 34 turboes (most people with stock 33 turbo's on seem to get boost about 500-700rpm earlier than im getting)and the 2530's i haven't heard complaints about, humm, decisions decisions
I guess it depends on personal preference. one man's laggy is another man's response machine.
I've driven an rb20 with an r34 turbo before. It was definitely more laggier than the stock turbo, but I wouldn't exactly call it laggy in the scheme of things.
Highflowing ports out the housing, and fits bigger wheels, so it'll just make it laggier again.
most people say the 2530 is a good match to the rb20, but keep in mind, that it is subjective. Response of the 2530 will probably be similar or slightly laggier to what you've got on there now.
IMO (I ain't no guru, so feel free to post otherwise), the response of an r33/r34 highflow is similar to that of a 2530. The highflow is a little bit laggier, but it makes more power.
Check out the thread about all people's turbo results.
Yeh, the car has had a remap, but i dunno just scores low, so i was thinking 2530 i'd be looking at 190-ish seeing as im making 163 now (which judging from other people results is low)
After reading what other people are saying i think i will go 2530, and just drop some softer suspension in the back to make up for the increased lag
+ when i get my gtr in october, i will already be half way to twin 2530's >_<
Edited by 123456
Ah crap! Guess i'll just try get the N1 model.. I wanted to achieve high 11's on the GTR, duno if the N1 turboes on a rebuild with minor mods will do that and i can just sell the 2530 turbo instead.. Alternately i guess 2 high flowed 33 turboes wouldnt go on a gtr either?
well a r34 neo turbo on a r34 neo engine gets you full boost at like 2800rpm. don't think you can say the turbo on it's own is the whole problem.
you say the split pipe and hi flow cat won't make a big difference? i wouldn't agree there, especially if you have a catback. a full 3" system from turbo back would make a HUGE difference, in terms of power and responsiveness. On an r34 you're looking at about a 30rwkw difference, that's a lot.
ahhh... r34 neo turbo at 14psi..... WHAT THE??
How come none of the rest of you have commented on that f**ked up dyno graph?
Did Sam not give you any hints as to why it peaks so early?
What revs do you make the 14psi?
I'd be trying to figure out what's wrong with it now before changing turbos.
mythbusters ahoy;
gtr turbo flange is different to gtst turbo flange
gtr twin turbo's are smaller than gtst single turbo
gtr 2530s are not the same as single 2530 for gtst
14psi on an rb20 is not the same as 14psi on an rb25 neo
split dump wont make any difference to turbo response
Go and have a chat to Sam
really that turbo should hold all the way to 8000rpm and not run outta puff like the stock turbo, and around 4000rpm the show should be on.
especailly since youve added a larger cat, that makes a big big difference over a compliance one!
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
