Ah true? He didn't mention it, just said maybe cam gears or something from memory. Need to save up a few hundred dollars for it to get dyno tuned again i spose, balls
Did I read that right...? you hit 14 psi at 5800 rpms?!?
Sounds like if you replaced your turbo/manifold gaskets you'd get better spool than if you upgraded to a ball bearring turbo!
Seriously, thats and unhealthy late spool.
This might be alittle off topic but then again it could help this guy out...Does anyone have a dyno graph of a sliding performace rb20 highflow on an rb20? it'd be good to compare it to all the other graphs on the rb20 thread...
Just had a look through the RB20 topic and dam theres something bottleknecking my car's performance bad. Most of the standard r32 turbo's are maxing at 140, some 145, mines alot bigger than the standard and it's maxing at 142 so something wack there. Most r33 turboes are making the power about 15-20 km/h higher than i am.
You're damn right there is!
I put down 219 hp, or 163 rwkw, at 12 psi on my rb20 turbo. SAFC, open downpipe, FMIC.
My roommates car made 258 hp 259 tq on his r33 turbo @ 16 psi.
Same here...i've got a standard engine with standard turbo, exhaust, fmic, fuel pump and dr drift remap and it laid down 160rwkw at 12psi too on Sam's dyno...so theres definitely something wrong with how much power you're making...
Edited by limpus
full boost should be lower....3500rpm on my cousins 32 with 33 turbo...
i thought that the comprimise of 500rpm of response for the extra power up top of the 33 turbo was well worth it...
also running 14psi on the 34 turbo on a rb20 is roughly the same as running 12psi on a rb25....
This was a write up done on Sliding Performance turbo's on an RB20DET proving that even the standard RB25 highflow is more then capable of creating 230rwkw. http://www.skylinesaustralia.com/forums/in...142615&st=0
Your power drops off far too early...
I've got max power at 6500rpm and then at 8000rpm I've got the same power as at 5300rpm. RB20 with R33 S2 turbo.
You should have something pretty similar seeing as you've got the same turbo except the bigger turbine housing.
Hmm damn, lots of responses saying it's shagged, sucks that it's not easily diagnosable (<< how the hell do u spell diagnosable) and the fact that the guy who tuned it didn't mention that it was dropping off prematurely worries me, hope my engines not rooted, i thought it was pretty good. Any one know of any dyno nights closer to greensborough/watsonia/eltham area coming up soon so i can see if the cat/dump has made any difference (i normally dont rev the thing past about 6.5k anyway)
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
