I bought these to get my gtr through compliance and then changed them for 18's.
The tyres are Bridgestone Potenza 225/50/16 RE540S fitted to stock S15 rims in near perfect condition. No gutter rash on any rims. They have about 70% tread on all four but two have some camber wear but would still have a few trackdays left in the camber worn tyres. Tyres alone are over $1200 new and the rims sell for $300 secondhand. Also I have a pair of R32 GTR rims to so with them painted white which can go with the set or will seperate for $200
After $675 lot. Six rims and 4 tyres.
I need these gone asap. No silly offers.
Gareth
0417370869
Please call beacuse I don't have internet at home yet.
Melbourne
Will frieght at buyer expense
Below are pics - 3rd, 4th, all four, 1st, 2nd as seen in the all photo from left to right.
1st tyre has slight camber wear with good tread
2st tyre has slight camber wear with good tread
3st tyre is almost brand new
4st tyre has slight alot more wear than I thought but tyre 3 evens it out
  • 2 months later...
GTR rims are sold. Will accept $475 for the S15 rims and tyres. Absolute lowest I can go before they go on ebay. When I bought them the second highest bid was $535.
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
