haha,
I forgot 3" exhaust
How hard are these things to remove
Gauges I can take off myself, do you need to remove the associated cabling aswell to pass regency?
Blow off valve and exhaust I will have to get removed at a shop, and replaced with stock
Suspension? can I simply have it raised or do I need to remove adjustable shocks and replace with stock?
https://www.sau.com.au/forums/topic/150440-defect/#findComment-2801471
3" Exhaust..
Get a coke can and chop it up to the flange shape. Then drill a few large holes in the sucker. Silicon it all up place it behind the cat. Wait for it to dry then run a bit of grease and oil in to it and get it hot to make it look a little aged. >_<
https://www.sau.com.au/forums/topic/150440-defect/#findComment-2801519
all depends what sort of suspension you have, if they are adjustable platform coilovers then you can wind them up but still have the risk of them not going through becauase coilovers are illegal, however when my 33 came over from japland my coilovers went through ok.
most of them time, if your guages are below the dash line then theyll be ok, keep tread on your rears, not too low, not too loud, dont be stupid on the road and they'll be ok about it
https://www.sau.com.au/forums/topic/150440-defect/#findComment-2801595
If this is you Mick, give me a holla and i'll give you a run down. And if you have bought a skyline, fly around sometime -> doing the speed limit that is :)
btw..has it got a defect, or you just asking? as most have written, most likely everything, and depending on how they're feeling at regency
https://www.sau.com.au/forums/topic/150440-defect/#findComment-2802027
i know the legal hight is 360mm,need stock plenum,NO bov doesnt matter if its plum back,no fuel regulators list goes on and on and on i was there yesterday aas i got defected for tint and boost gauge..
really because i have my boost gauge mounted on my dash, beside the stereo. i hvae had my car defected twice
during my defect saga. there has never been any attention on the boost gauge.
more attention on abs, rear wheel steering and engine emissions... :laugh::D:(:):)
https://www.sau.com.au/forums/topic/150440-defect/#findComment-2806505
Plum back bov is a std piece of equipment and must be in along with all piping and recirc. hoses...
Aftermarket bov's are not allowed.
The same as what I was told... The afm to turbo pipe, cross over pipe, the std bov and its pipework cannot be touched. FMIC is allowed providing there's no cutting of the body and it doesn't hang lower than 100mm.
https://www.sau.com.au/forums/topic/150440-defect/#findComment-2808556
Hey Guys,
Wot in SA do the cops defect u 4. I have moster tach, shift light, boost gauge, blow off valve, adjustable suspension (now low).
if it is a brand new exaust you should of got a silencer with your rear muffler otherwise known as the cannon wich passes you through regency as i have just passed with a 4 1/4 hiflow exhaust system
and bassically everything in which you listed in your last quote i got done for as well not to mention the rest.
let us know if you ever need to borrow a silencer.
https://www.sau.com.au/forums/topic/150440-defect/#findComment-2812146
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
