Just want to know how long it took to install your FMIC kit and did it all both together properly? how much clearance did have, what did u have to do to make clearance.
It took me and 2 mates all (mechanics) 6 hours flat out from start to finish. tbe pipes on the driver side didnt match up and i had to remove the washer bottle (going to have to relocate it or modify the bottle eventually) hacked the hell out of my front bar (on and off 10 times).
I had pipes missing (cut up old pipes to fit, didnt really matter allowed me to keep my BOV) joiner missing (used a factory one) had to cut and rework the drivers side cooler pipe to fit.
Anyone else had a bad experience with one of these coolers? anyone find the instructions vague? or is it just me owning a Sedan?
Final result came good despite our improvised installation proceedure
  • Replies 46
Posted Images
what brand was it.
the GTST hybrid kit took 3-4hours both mechanics the GTiR hybrid kit took 4ish-hours was litle bit harder. and hopefully the R34 and S14a wont take more than 4 hours or i might have to charge more.
couldnt u mount it further back to clear the front are.
oh and the instructions arent acurate and just have a pic saying cut here bolt ther...
Thats why the kits are cheap mate, they dont fit for shit.
Took a mate and i 6 hours + to fit my cheap brand intercooler.
If i was going to do it again id save up for something that comes with stainless cooler pipes and uses the factory pipe positions.
Cheers
Don't know whatyour on about. IT TAKES TIME AND PATIANCE. one of my mates put his in and took 4-5 hours but things didn't line up, mainly because he rushed it and cut the hole wrong and so forth.
I have the same kit, took me most of the day but i was doing other things at the same time, one hole, didn't have to move the washed bottle, didn't come close, and it fist like a glove. I had the cooler on and off about 12 times to make sure it allined and fitted how i wanted it. I din't modify any of the pipes, and they were exactly the same as my mates.
So i think maybe you did something worng?
Did mine (a kit from CRD $400 ) in around 4hrs. It all lined up and fitted well. Nothing to be cut or modified.
It was all straight forward.
Im with you mine waws faily straight forward, the passenger side factory hoe had to be enlarged and a hole cut in the driver side but it was or a non event.
If i did it again i would but a kit that used the stock pipes in the engine bay. I dont like hte idea of the cooler pipe in between the radiator and engine where it gets very hot.
The kits from Just Jap and CRD are the same, which highlights the fact it comes down to whos fitting the kit.
Wether or not someone is a mechanic or not is completely irrelvent, in fact blind freddy could install an intercooler kit!
Cheers
Let me guess, you have tried to install your own intercooler kit before and failed miserably? Because your comment above is complete crap :cheers:
Spot on.
From my experience, it only takes one pipe to be slightly out of alignment for the whole overall fit to be thrown out.
I always do a dummy fit and pipe alignment before cutting the hole in the guard, and trim the front bar a little bit at a time to get it just right - if you take the time and patience while fitting, you will end up with a good quality result :D
like i said, mine fited nicely, no problems, no nothing, exactly how and wher it should have gone. YOU just need time and make sure everything is allinged, the hole in the right place, and so forth.
Edited by WogsRus
Sorry to be the one to point it , but it was your install that went pear shaped im afraid.
As for your BOV pipe, you dont need to touch or go anywhere near the plenum crossover pipe that the factory BOV is mounted on when installing any front mount kit
Well my problems arose from my car being Type-M and having that extra lip at the front (is it for stability or something?) It stopped everything from aligning up and the kit sticks out so far that it pushes the kit out on both sides at the front (which now needs a respray) Cutting the battery hole was a bit of a pain but meh, most annoying thing for me was on the right side of the engine, trying to align the piping into the original elbow. Other than that and quite a few badly welded fins (onec again, meh) it's good, looks fairly decent, and well i can't notice too much of a drop in performance cept for the obvious throttle lag
you need to trim the stock plastic fornt bar to accomodate for the piping and FMIC. I had to trim about 4cm of mine to fit and it looks good no problems at all.
What needed to happen was to install the top pipe and cut the hole in the guard to accomodate that position. If i did mine as per instruction it would have possiblt not allined as well as it has.
All the welds on mine look A1, my mate is a welder and was very supprised when he saw it.
I had never done this before and bought a unbranded kit off ebay.. No instructions so got the Hybrid ones which are close.
Took my time and did it bit by bit with no help.
Took a few weeks to get the courage to go full-on and finish it.
CUt the front bar and a few odd bits on days here and there.
Removed the front bar and replaced about 8 times bofore finishing.
When i finally went for it and removed the SMIC/drilled/cut/smoothed edges...ie complete fit did overnight.
Very satisfying ! :)
http://www.skylinesaustralia.com/forums/in...110032&st=0
Well I took one morning and whole afternoon to get it fitted. Fits quite well. Have to "trim" the front reo bar a bit and have to trim the front bumber as well. The pipe lined up very well and the only thing that did not fit in at the end is my blinker as I have a series 1. Fit a cheap blinker from supercheap store and problem solved.
The kits fits like a custom one... you have to trial fit it.
no workshop putting something in would just "put it in" without doing a dummy trial... so you should be doing the same.
on that point i failed to mention my aftermarket BOV was on the intercooler to plenum corssover pipe not on the plenum crossover pipe (not me, came from japan like that) and the instructions said the box should contain 4 pipes for RB20/25, etc but there were 3 and 2 silicon joiners when the instructions said 3. ill get a pic of the engine bay to shou the end result. Being a Sunday there obviously wont open.
But in saying all that the performance has improved quite a bit.
next mission - what to do about my washer bottle
Depending on where you went thru your washer bottle....
Other kits were meant to go thru there and were supplied with half size/replacement bottles. (i think from memory)
That might do the trick :kiss:
i have the same kit, took me 6 hrs to do it on my own...
my washer bottle sits right above where the pipe comes through you should be able to make that pipe sit lower and keep the factory position of the washer bottle...
i had to shave my bar to clear the cooler, i had to shave bits of the A/C thermo and had to shave the tips off my clutch fan & cut the hole under washer bottle...
did your clutch fan clear that pipe running up top near radiator???
there is a little screwing around involved but value for money is TOPS! :kiss:
LOL
I can see how someone can fail at fitting an intercooler kit, seeing as they go on a heap of different ways and all.
we mocked everything up, cut the hole where the instructions said to and we still had to cut a 3" section out of the pipe going from the cooler to the intake plenum.
And yes i had to cut the shit out of my front bar to make it fit but thats to be expected.
    • PRICE  : $1400 LOCATION   : NSW Central Coast FIT  :  All Nissan 350Z type Z33 and Infinity G35 Coupe. See delivery note. Hi, brand new, unused, still in the box.  ($1850.00 is what i paid ) My bad luck !!! I thought my right front  Bilstein was cactus so i bought the ST 's to replace all.  Turns out the right front is fine ( loose mounting after service  by a well known importer of Bilsteins ) So im selling the ST's. They are made by KW ( no intro needed ) . Iam on the Central Coast and im willing to meet up in Sydney metro, within reason and Newcastle.
    • Yep, yeah would need to do the flywheel although the 6 bolt NA clutch can handle a 20de if just wants to replace the stocker.
    • No it's fine. Heat sleeve is a thing. With oil running through it it is unlikely. Engine off heat soak can be a thing though. There is no way that you have a leak through the hose. That has pressure behind it and any small hole will turn into a large one in very short order. It is so much more likely to be leaking from the connection.
    • Really? That's piss weak. I didn't know they hobbled the shitboxen that badly. OK. So probs need to buy a flywheel too. But that's not too bad.
    • Hi all. I already posted some newbie-ish questions here and there but this will be my first "big" post. Last summer I went and fulfilled a kind of childhood wish, because I just thought I needed this experience in my life no matter what. The car I bought is a mildly modded 1995 BCNR33 Vspec. It was repainted to a metallic orange color all around and it had all windows reseated. Not so well done black respray in the trunk and a metallic black in the engine bay. From outside it looks very nice except for a minor paint error on the roof and the rear spats needing new adhesive tape. The inside is pretty clean and no broken plastics, missing or faded buttons. Even the adjustable mirrors and trunk antenna work like a charm. Despite a moderately long list of issues I don't (yet) regret buying this car. Most mechanical problems are just due to age, like worn rubbers here and there. The underside sadly has lots of corrosion, especially to the back. It looks like it either has been driven in the winter for a while or it lived near the saltwater in Japan, the rust is nothing terrible but it'll require to be looked after. Mostly panel gaps and all the mounted components underneath are a bit crusty, but I don't think anywhere has progressed so badly that there's going to be holes. Front right jacking rail is crushed and needs some care so it doesn't develop into a rust crater at some point. Worst part is definitely the strut towers. I thought they looked fine but after taking off the strut bar I noticed that it actually started bulging up on the passenger side. Probably would have passed on the car or negotiated down by some thousand Euros more if I had noticed this before buying, but here we are. Trunk area also has signs that there was a water leak to the interior once but nothing too crazy, I guess lots of Skylines had this at some point. As for the list of (known) issues, I'll try to make this compact. I hope the coloring is self explanatory. Mechanical: -Various busted or soon-to-be busted rubber bushings and ball joints. Will replace ball joints with OEM or better and bushings with polyurethane where possible. -Shaking steering wheel at above 80kph -downshift from 5th to 4th is a bit crunchy unless I rev-match, might just try to renew the shifter assembly, but it's not a priority issue -tailshaft centre bearing could use a replacement, is it worth going 1-piece tailshaft as it doesn't look too fresh all around? Chassis: -underbody corrosion on many spots and in hollow spaces, needs to be treated -corrosion on many bolts, hoses, lines, suspension components, subframes, will be treated when replacing of the bushings is needed as time goes on -strut tower top panels and some of the surrounding panels are rusty, so needs fixing. Will look into doing this with a buddy in the winter, otherwise bite the bullet and pay a professional -driver side door is misaligned to the body and needs to go a slight bit more inwards -both door windows are misaligned and have an airgap where the window meets the door at the B pillar -The Aerocatch latches for the bonnet have locks but no keys, need new keys. -driver side door window is kind of gritty and could use a polish -damaged jacking rails and front frame rails, from people lifting the car the wrong way, might have this fixed by a bodyshop Electrical: -Nismo tachometer is just bouncing and displaying nonsense, supposedly worked fine when the stock ECU was still in the car -An old Greddy boost controller sits on the dash which will be removed as it servers no purpose anymore. -a led segment rpm gauge is on the steering column, will probably also be (re-)moved once the Nismo tacho is working correctly -there was an attempt to make the sound system better by the previous owner but it was just inducing noise all the time, ripped out the amp and filters in the back, no music for now -trunk antenna goes up as long as the radio is on regardless of the mode, I want it to only rise if I choose Radio specifically or per switch -3rd brake light is a bit dimmer than the taillights but everything was converted to LEDs so mabye now it just seems dimmer? -reverse light flickers, have to test if that behavior changes when I fiddle with the gear stick. Hope I can get around changing the switch. -Left side taillight, blinker section has minor water intake and is humid after washing. Other side has a hole in it, probably for that exact reason. I'll probably reseal them entirely and plug the holes. Engine: -minor coolant drips on one or the other hose -rear turbo leaks oil onto the exhaust making the car essentially undriveable due to fire hazard -Oil filter relocation kit has an oil drip at the Dash lines, will probably make a new connection there and tighten real good and pray -throttle body assembly is slightly stuck for the first throttle pedal input after sitting for a while I'm always open to suggestions and advice from more experienced people, I'm sure half of this list is easily dealt with and just requires some time and effort to sort out properly. Once I have some proper pictures of the car I will post some in this thread, I just have to remember to take some more once I get the chance to. Will post updates when I have news on anything, I want to try to keep this thread as kind of a logbook as well. Ultimately my goal for this car is to just enjoy it. An engine rebuild is probably going to happen sometime as well, because it is old after all. It will never be fully new again, I am just not that rich. But I want it to look good, work well and not rot away while I drive it. I'm probably gonna spend a lot of money on this journey, hopefully not an unreasonable amount.
