Edit: Seems like you got a 4 door.. Could be a totally different story then.. hmmm
Yes that seemed to be the problem. After looking at a 33 S2 Coupe the washer bottle on them is where the battery is on my 4 Door, and my washer bottle is under the battery. Anybody else put a FMIC kit on an S2 sedan? if so what did you do about the washer bottle.
  • Replies 46
Posted Images
ok finally finished the install today.
for the hole under the battery i didnt really care about the holes being flush so i just made a big hole to suit... although its still touching a tiny bit.
that same pipe also touches my powersteering lines (not A/C). i also had to trim my fan blades aswell as the end of the pipe that connects to the BOV pipe as that was too far forward. the other cut was also the big oval in the original hole.
i was able to onli hack away at my front bar only a little.
i didnt follow the instructions coz i didnt want to cut my reo bar, in the end i mounted it onto the reo at the top and the side tanks seem to rest on it a little, but it is rock solid does not move an mm. i think this is part of my reason why the other pipe hits the P/S pipe. as its too far back.
all in all i could feel the difference today and for the price u pay for this kit it is quite good.
  • 4 weeks later...
Thinking of buying one of these. I see that you have to cut the reinforcement bar.
On a series 1 R33 with a stock bar can you just mount it behind there without any visual trimming of the plastic on the front bar. I realise the air flow might not be the best but should still be better than the smaller SMIC's.
It would be good if it came with black silicon joiners..I'm thinking of spraying the whole kit black so it isn't visible.
So the consensus is that these kits are quite good?
If anyone is interested, I have a qualified mechanic friend looking for work at the moment. He has just moved back from QLD to Sydney just this week. Mentioned that if I can get a few people together, he would fit for $250 per kit.
PM me if you are interested and I will forward details onto him. I'm hoping to get mine done too. He previously worked for Nissan in addition to other performance work, Turbo's and V8's.
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
    • Probably. I take it that they are also mentioned to be for R34 Skyline? For example.... RDA has that part as RDA7957. I have the dimpled and slotted version of that on my car https://www.ebay.com.au/itm/285518478694?srsltid=AfmBOopKxMuAFpsxZJdB1cam4D5RAj1f9yJyOttPZLAwXVNCOiwlhrIy This is DBA's top one piece equivalent https://www.ebay.com.au/itm/364246686631?srsltid=AfmBOorbb0XHQgqTvZLgQPhg70nqJtGvdojKnugum3O2LFSr2h-obp8D
