Hi all,
Its time to sell my Skyline as I have bought a house and unfortunately can’t afford and maintain both. My loss and your gain. It’s a late 1994 Nissan Skyline GTSt that I have had for the last 6 years (only 2 of those years has been spent on the road). I imported it from Japan with 64000kms and the current Speedo reading is 88000kms. Mods are below.
EXTERIOR
Bishop Blue paint – PPG paint (includes engine bay, doors and boot)
EAST BEAR GTR front bar and grille
Genuine GTR clear indicators
Nissan Type M side skirts and rear pods (plastic not fiberglass)
Genuine GTR Rear wing (plastic)
New window sills and rubbers
INTERIOR & AUDIO
Custom dash (silver with blue pearl, also gauges were lighter and ashtray was)
Carbon fibre steering wheel
Nismo horn button
Recaro Seats front and rear
Apexi pen type turbo timer
Pioneer double din unit
Sony explode splits – front
Tinted windows
GTR Cluster
INTAKE & EXHAUST
K’N Air filter with 3inch stainless pipe to turbo
Giwasa 600 x 300 x 76 front mount intercooler
Custom 3inch front pipe (to cat) in 316 stainless steel
Bee R 3.5 inch exhaust (from Cat)
Custom 2.5 inch screamer pipe – stainless steel
Greedy plenum
Q45 3.5inch throttle body
Z32 Airflow meter
Just Jap engine brace
Custom blue air box
Bass Junky Raidiator air guide
ENGINE
Custom blue rocket covers, timing belt cover and coil cover
Aerospeed cam gears
Ported head (flow bench 276hp)
Race springs, lifters and valves
O ringed block
Forged pistons
Shot and pined rods
Balanced & machined crank
ACL bearings
GTR water pump
GTR oil pump
Just Jap Oil cooler and remote oil filter
TURBO FUEL & ECU
Garrett GT3540 700hp turbo (dual ball bearing)
Turbo smart 48mm Pro gate
Custom ASE highmount exhaust manifold
Apexi Power FC and Commander
Sard 650cc top feed injectors
R34 GTR fuel rail
Sard fuel pressure reg
Bosch 044 fuel pump
Custom built catch can
Trust Type R BOV with stainless pipe back to intake
DRIVETRAIN
Factory Nissan 5 speed manual
5 puc button clutch
GTR pressure plate
Nismo locker
SUSPENSION & BRAKES
Tein HR adjustable suspension
Factory brakes and discs
Factory ABS
Highest power figure to date = 347rwkw @ 20psi (currently tunned to 310rwkw @ 16psi - everyday driving)
Nothing was overlooked when building this car and it has been my life for the last 5 years, I am looking for $28000 ono (spent over 50k not including car). Please no time wasters or test pilots. I am located in Melbourne and the car has Rego till November 26th 2007. Better pictures will be added shortly
****SOLD**** with standard GTSt wheels
Now featured in Issue 78 of High Performance Imports.
Call David 0400 261 099
Edited by XZLA.8
  • Replies 51
i was / am on the market for a GOOD gtr - normally you pay alot more for those badges!!
do you happen to have the standard 25t grill in blue which just has the skyline logo on it?
id love a gtr, but id also LOVE a completely worked 25t which has NOT lost its soul.
just may be hard to get a perfect colour match in such a nice, but custom colour!! (i love it)
please let me know!
please let me know!
I dont but im sure I can get one - the colour is a Factory Blue from Toyota and matching it is not a problem as the front has been resprayed and there is no difference between the bar and guards.
  • 3 weeks later...
****SOLD****
I will also consider any serious offers over $26000
Also updated power figures = 347rwkw @ 20psi (currently tunned to 310rwkw @ 16psi - everyday driving)
Cheers
Edited by XZLA.8
  • 1 month later...
hey mate
intrested in ur car.
whats the lag like with that hi-mount?
What the GB like?
Clutch still holding up ok?
Are u using the PFC for the boost control?
KJ
hey mate
What the GB like?
KJ
Hi Mate
hardly any lag would you belive it hits full boost by 3200 - 3800rpm clutch is still good no signs of slipping as it only been in since November. No PFC boost controller just a simple boost controller off the wastegate (simple but effective)
what do you mean 'GB like'?
Cheers
David
Car is currently featured in Issue 78 of High Performance Imports Magazine.
However please keep in mind that the pictures and tech sheet were submitted in Sept 06 and its now making more power on less boost as changes have taken place since.
Cheers
$26'000as is FIRM
I am willing to give 2% of the sold price to the person who helps sell the car.
So if you know someone in the market for a stunning skyline let them know about mine.
Contact me for more details
0400 261 099
Cheers
David
Edited by XZLA.8
Wow, that is quite possibly the cleanest 33 I have ever seen!!!!!
I just spent $38k on a newer car recently, and I know people always say this, but I would have bought this car for sure had that not been the case.
Very,very nice car mate..... Good luck with the sale :P
  • 2 months later...
  • 3 weeks later...
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
    • I had the same previously, and it really shits me. They just run off red book averages or whatever as the maximum insured, there are never good quality cars available to buy for anywhere near those prices. I don't even understand why they do it. Sure having a customer overinsure then false claim is a risk, but how often does that really happen in the world, 1%? 0.1%? On the other hand, all 10-20% above redbook listed prices and charge 10-20% higher premium, surely that is more profitable for those cockroaches
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
