Stunning Electric Blue R33 With Power To Match 347rwkw
Hi all,
Its time to sell my Skyline as I have bought a house and unfortunately can’t afford and maintain both. My loss and your gain. It’s a late 1994 Nissan Skyline GTSt that I have had for the last 6 years (only 2 of those years has been spent on the road). I imported it from Japan with 64000kms and the current Speedo reading is 88000kms. Mods are below.
EXTERIOR
Bishop Blue paint – PPG paint (includes engine bay, doors and boot)
EAST BEAR GTR front bar and grille
Genuine GTR clear indicators
Nissan Type M side skirts and rear pods (plastic not fiberglass)
Genuine GTR Rear wing (plastic)
New window sills and rubbers
INTERIOR & AUDIO
Custom dash (silver with blue pearl, also gauges were lighter and ashtray was)
Carbon fibre steering wheel
Nismo horn button
Recaro Seats front and rear
Apexi pen type turbo timer
Pioneer double din unit
Sony explode splits – front
Tinted windows
GTR Cluster
INTAKE & EXHAUST
K’N Air filter with 3inch stainless pipe to turbo
Giwasa 600 x 300 x 76 front mount intercooler
Custom 3inch front pipe (to cat) in 316 stainless steel
Bee R 3.5 inch exhaust (from Cat)
Custom 2.5 inch screamer pipe – stainless steel
Greedy plenum
Q45 3.5inch throttle body
Z32 Airflow meter
Just Jap engine brace
Custom blue air box
Bass Junky Raidiator air guide
ENGINE
Custom blue rocket covers, timing belt cover and coil cover
Aerospeed cam gears
Ported head (flow bench 276hp)
Race springs, lifters and valves
O ringed block
Forged pistons
Shot and pined rods
Balanced & machined crank
ACL bearings
GTR water pump
GTR oil pump
Just Jap Oil cooler and remote oil filter
TURBO FUEL & ECU
Garrett GT3540 700hp turbo (dual ball bearing)
Turbo smart 48mm Pro gate
Custom ASE highmount exhaust manifold
Apexi Power FC and Commander
Sard 650cc top feed injectors
R34 GTR fuel rail
Sard fuel pressure reg
Bosch 044 fuel pump
Custom built catch can
Trust Type R BOV with stainless pipe back to intake
DRIVETRAIN
Factory Nissan 5 speed manual
5 puc button clutch
GTR pressure plate
Nismo locker
SUSPENSION & BRAKES
Tein HR adjustable suspension
Factory brakes and discs
Factory ABS
Highest power figure to date = 347rwkw @ 20psi (currently tunned to 310rwkw @ 16psi - everyday driving)
Nothing was overlooked when building this car and it has been my life for the last 5 years, I am looking for $28000 ono (spent over 50k not including car). Please no time wasters or test pilots. I am located in Melbourne and the car has Rego till November 26th 2007. Better pictures will be added shortly
****SOLD**** with standard GTSt wheels
Now featured in Issue 78 of High Performance Imports.
Call David 0400 261 099
Edited by XZLA.8
  • Replies 51
i was / am on the market for a GOOD gtr - normally you pay alot more for those badges!!
do you happen to have the standard 25t grill in blue which just has the skyline logo on it?
id love a gtr, but id also LOVE a completely worked 25t which has NOT lost its soul.
just may be hard to get a perfect colour match in such a nice, but custom colour!! (i love it)
please let me know!
please let me know!
I dont but im sure I can get one - the colour is a Factory Blue from Toyota and matching it is not a problem as the front has been resprayed and there is no difference between the bar and guards.
  • 3 weeks later...
  • 1 month later...
hey mate
intrested in ur car.
whats the lag like with that hi-mount?
What the GB like?
Clutch still holding up ok?
Are u using the PFC for the boost control?
KJ
Hi Mate
hardly any lag would you belive it hits full boost by 3200 - 3800rpm clutch is still good no signs of slipping as it only been in since November. No PFC boost controller just a simple boost controller off the wastegate (simple but effective)
what do you mean 'GB like'?
Cheers
David
  • 2 months later...
  • 3 weeks later...
 Share
    • So.... when I'm finally getting around to having my power steering leak sorted, now it looks like I've got the same issue most A/T Skylines are having. My A/T light will randomly come on and I'm stuck in 3rd gear until I turn the car off and on again. Only 3 weeks ago I did a complete transmission service: Oil flush + new gasket + new filter. This came out of nowhere!! It wasn't like the car was driven hard. I drove about 3 mins down the road to get fuel and boom!!!  Anyway, I have a few questions and hope you fine people can help me out here. All questions are in red. 1. The solenoids: I was looking at the parts catalogue in Amayama and I could only find the Solenoids as an assembly. https://www.amayama.com/en/part/nissan/319404ax05 I read in another thread that Solenoid A = 31940-4AX02 & Solenoid B = 31940-4AX05 but the Amayama product has only the code of B. Is this the right part? Can anyone who has done the Solenoid changes or seen them confirm if this is the complete set of A & B?   2. Gasket and Filter: I'm not going to try change the solenoids myself because it seems difficult to do in a home garage with just 2 jack stands. I plan to take it to a shop and get it changed. I was also going to buy the transmission sump gasket at the same time so I don't reuse the same gasket. Should I just use the existing gasket as it has only been on the car since OCT 19th? (~3 weeks) Should I be buying a brand-new gasket and a filter? Does this job involve taking the filter out?   Thanks in advance to everyone. It's hard to find a video of someone doing a solenoid change on a R34 so any help you can give answering my remaining questions would make me less stressed.
    • Yea - From what I have seen from the video, the car idles like any R34 lol 50PSI of fuel pressure is hardly super abnormal, the regulator is working because the pressure remains static when the throttle gets revved, i.e pressure remains the same when manifold vaccuum changes. Bigger pumps on stock rails always bumped the pressure in the rail without using an aftermarket regulator to change that. Do you know what your IAC is actually doing? Has there been any data showing the stepper motor % etc? There's no way your idle is actually moving around the way the cluster(s) are indicating. You would hear the difference with the engine RPM flying to 3k and 1k in mere seconds. I'd be checking the wiring to the tacho. What the tacho is telling you and what the engine/ecu is telling you are different things. I assume your ECU doesn't display the spike. So whatever is telling the tacho to be at X rpm is doing something weird. When the going gets insane, you're on the wrong path. You've ruled out plenty of things that are working correctly/aren't the issue. Your idle isn't doing what the tacho is indicating. You have two seperate issues, I don't think they are linked, and the idle seems reasonably okay unless it's stalling which.. well, it hasn't. Troubleshoot the stall if it occurs by figuring out what your IAC is doing vs what it is being told to do.
    • So awesome! I love the RB with the exhaust on display.
    • NO HITS PRICE DROP   ENGINE - $8.5k ONO TRANSMISSION - $1.8k ONO
    • If it has had a code in the recent past, the code should still be there waiting to be read.
