for sale:
93 rb20det motor package
approx 75,000kms
includes:
complete motor: sold
gearbox: sold
flywheel: sold
HD 5puck clutch: sold
inlet manifold and plenum: sold
injectors: sold
throttle body
6x new coil packs: sold
exhaust manifold and turbo and sheild: sold
3in dump/front pipe: $100
2.5in piping for front mount: sold
radiator: $100
power steering pump
alternator
air con compressor
starter motor
r32 crossmember and engine mounts
gearbox mount
tailshaft
lume
think thats all of it. it is pretty much a complete front cut minus the car chassis part
prefer to sell it all together but might consider seperating the gearbox from the complete motor from the mounts etc providing i get the right price for all items
#edit# sold the major parts so reasonable offers accepted on the remaining items
please reply to pm as i don't check the thread much (but give it a bump anyway)
located near (west of) brisbane (ipswich for the locals)
also for sale:::
*apexi twin chamber bov. $150
*z32 hubs/spindles. $100
*s2 rb25 turbo. guess you could say its blown. has a bit of shaft play and is a bit noisy/squeals. great for rebuild/hiflow. sold
*s14a complete rear cradle (includes cradle, lsd diff, halfshafts, all control arms etc, hubs/5stud spindles, swaybar, rotors, calipers, handbrake cables, etc. $500
*absolutely heaps of s13/180sx parts (just ask for what you want cos i've probably got it)
Edited by rb20inside
https://www.sau.com.au/forums/topic/150538-rb20-conversion-package/
bov is atmo and needs an adapter. however, i also have a short piece of pipe with the appropriate flange on it though, which i can include.
motor gone, rest of the parts still available
no more clutch/flywheel
gearbox now gone also
crossmember/mounts and LOTS of minor bits now for sale individually
cheers lads
how much for the manual driveshaft and do you still have the brake and clutch pedals and the hydraulic clutch lines.
needed for a manual conversion i heard you can retain the auto gearbox mount when doing the conversion
  • 4 weeks later...
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
