After a cheap stock radiator should have mentioned sorry.
No such things a "cheap" and imports :D
Have your tried any of the wreckers at all, there not the easiest thing to come by as when there smacked in the front there normally one of the first things damaged as you would know :kiss:
https://www.sau.com.au/forums/topic/150574-r32-radiator/#findComment-2803852
Yeah theres a '32 at the wreckers up here but as you said radiator was one of the first things f**ked in it.. There's 52mm alloy ones on ebay at the moment for about $250 new that's been the best option so far.
Just be carefull with some of the ones off Ebay they are straight up NASTY!!!
Send Benno a PM and see what the damage on one of the custom ones are as they are the ducks guts and great build quality :kiss:
OR you can buy my stocker and i'll put a PWR one in :D
https://www.sau.com.au/forums/topic/150574-r32-radiator/#findComment-2803916
Just Jap ally radiators are good, about $300 or so. I have seen two now, VERy good build quality.
The Cooling Pro ones Just Jap have are $399 + postage so if you were after an alloy rad you would be better off buying one of the ones from BMS
https://www.sau.com.au/forums/topic/150574-r32-radiator/#findComment-2805192
I have a just jap one. good quality and my car runs alot cooler think it cost me 430 delivered.
If I knew Stu (BMS) sold them, I would of got one off him.
https://www.sau.com.au/forums/topic/150574-r32-radiator/#findComment-2805437
BMS? who that?
BMS
Dont get me wrong the Cooling Pro ones aren't bad for the price but i would rather support a local and i've seen a few "dodgy" AM alloy Ebay specials :thumbsup:
https://www.sau.com.au/forums/topic/150574-r32-radiator/#findComment-2805474
wicked, i didn't know there was alocal tasy crew who sold all this gear.
Where is Beechys?
Based in Launie cobber.
There are a couple of Just Jap Reps here in Tassie:
BMS
Beechy's Service Centre
and im not 100% sure if he still is seeing as he is the head honcho at Octagon now but Perrywinkly is the Just Jap rep for Tassie :P
https://www.sau.com.au/forums/topic/150574-r32-radiator/#findComment-2808999
BMS have a few R32 radiators and silcone radiator pipes in stock, including a very nice alloy one I'd bough for the GTR (Triple core, 40mm and fits the standard shroud) that I never got around to putting in... and seeing has I just bought an FD RX7 I doubt its needed anytime soon!
Brand spankers for $350 if anyone wants it.
https://www.sau.com.au/forums/topic/150574-r32-radiator/#findComment-2811045
    • The way they do the test you would be very lucky to ever hit any cell that isn't aiming at 14.7 This was my result... Really not sure what's going on there!
    • I have a projecta one.  A proper trickle charger can be left attached 24x7, that's what the trickle bit is about.
    • With an electronic boost controller, there are settings available to limit overboost.
    • Ah ok, my tuner did adjust something on the percentage cycle on the boost controller, instead of running at 40% the tuner put it on 20% to compensate for the overboost, can't remember what it was. Not duty cycle don't think, and told me if it keeps overboosting, it's going to be something else. I think he mentioned the turbo actuator.
    • Which trickle charger does everyone use? I'm going on holidays in the future, and last time it was left for a couple weeks off twice per time, and don't want to keep doing it to damage my battery so looking to have something hooked up to the battery which connected to the car, as I need to keep my immobiliser system on. If the battery goes flat it will mess up my security system (already happened once) I was looking at the following, so can have someone turn it on every couple of days and run it overnight then turn it off)   https://www.supercheapauto.com.au/p/noco-noco-genius-5-battery-charger-6v-12v-5-amp/648987.html?cgid=SCA01060203#srsltid=AfmBOoq4kzQgrm1YHSZT0DzaCwVwwOcevgu0TSDcUvrNeOqI-0S5xJ1C&start=1   https://www.supercheapauto.com.au/p/century-century-cc1206-xli-12v-1-3-6a-9-stage-battery-charger/693006.html?cgid=SCA01060203#srsltid=AfmBOoq4kzQgrm1YHSZT0DzaCwVwwOcevgu0TSDcUvrNeOqI-0S5xJ1C&start=30   though these don't say anything about trickle charging, don't want it to overcharge the battery.
